Originally Posted by
fixtureman1
I used .75 MDF .5 bit cut .375 deep sealed the edges with 2 coats of 50 50 glue and water. surfaced a piece of ultra lite MDF on one side the flipped it and glued it down using the vacs to suck it down with a piece of ply on top of it. Ran the vac for about 2 hrs then let it set over night surfaced the top top open it up and level it. Hope this helps
Thanks, I'll give this a try. I guess my problem was cause by making the squares to small.
I have seen some pictures of plenums with fairly large squares, that have small, maybe .125" grooves milled into the top of the squares.
James Harvey
Harvey Development Corp.
www.Harvey-Development.com
36" x 52" CNC Router
ULS-25E 12" x 24" Laser Engraver
