588,053 active members*
4,103 visitors online*
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Oct 2006
    735
    I didn't make any changes to the code far as the parts to find and react to index pulses. It does not rotate 2 forward most of the time. Uasually only rotates around 1/2 turn forward then 1 or more back. Serial number indicates mine is the differential version for all the sizes I have. When I rotate it manually the I/O screen check boxes look like any other encoder I've ever watched it react to.
    When rotating it watching the possition counts on the axis screen, I want to say they have always made sense. or seem to count right, but will look again.
    Will keep playing with it I guess.
    b.
  2. #22
    Oct 2006
    735
    Ok..
    Counts are for sure nice and smooth in the axis screen, I don't think it is having any issues seeing the differentials.
    Best I can do for the moment is watch the I signal with my meter. With a 120 ohm resistor to ground when spinning manually or with the program I see 4mv of power at that pin. When it hits the signal point in rotation I can see a moment spike of power. seen anywhere from 25mv to 50mv. perhaps a 75mv or 2..
    Not sure if that helps. But that is what it looks like on the I signal. If I disconnect that signal pin from the snap IO 80 the program will rotate for ever in one direction and never stop.
    b.
  3. #23
    Oct 2006
    735
    The differentials toggle nicely on the meter between 3.3v and 3mv when rotating.
    Sent some mail to teknic asking about their servo I output and what it could drive. See what they say. They had responded to me in the past on things when I was out looking for servos and got these.
    b.
  4. #24
    Oct 2006
    735
    Success, I think..
    Anyway connected the output of the I encoder wire to the one of the opto + signal inputs, and grounded the opto -. And then changed the !zmark and zmark commands in the program (seeing the opto is high unless triggered looks like) and now when I run I get 2 rotations one way then 2 the other and stop
    And the all important reports:
    REPORT
    0 Position = -329779 PhaseAngle = 3.814000
    1 Position = -337779 PhaseAngle = 7.814000
    2 Position = -329780 PhaseAngle = 3.510000
    3 Position = -321780 PhaseAngle = -0.490000
    Counts per rev = -8000
    Counts per cycle = -2000
    Counts per cycle (rounded)= -2000
    invDistPerCycle (rounded)= -0.000500000000
    Commutation offset = -824
    Input Gain Specified = 1.000
    REPORT
    0 Position = -7973 PhaseAngle = 3.814000
    1 Position = -15973 PhaseAngle = 7.814000
    2 Position = -7974 PhaseAngle = 3.510000
    3 Position = 27 PhaseAngle = -0.490000
    REPORT
    0 Position = -8000 PhaseAngle = 3.814000
    1 Position = -16000 PhaseAngle = 7.814000
    2 Position = -8001 PhaseAngle = 3.510000
    3 Position = 0 PhaseAngle = -0.490000
  5. #25
    Oct 2006
    735
    Now I think that looks correct. Is it ok to use the opto intputs for this speed/reaction wise compaired to the ttl? from the schematic, it looks like there is a series resistor to the opto so they can be connected to 5v directly. Hope so as I will probably use these IO for my estop/home inputs.
    Now that (I think) that is working smooth, what is the next step?
    b.
  6. #26
    May 2006
    4052
    Beautiful Bill. That looks perfect.
    So all this was to verify the hardware (phases, encoder, index) is working and to get two parameters for your 3phase motor:
    invDistPerCycle = -0.0005
    Commutation Offset = -824
    If you put these values into the HomeBrushless program then the motor should phase find to the index mark, commutate, and servo properly.
    Regards
    TK
    http://dynomotion.com
  7. #27
    Oct 2006
    735
    Ok. Will try that tomorrow
  8. #28
    Oct 2006
    735
    Cool, Looks like I can get movement in the step/response screen with this servo. Nice and smooth (as expected, just takes a bit of me trying) Now just have to remember PID tuning, although this will probably be a bit different then tuning the kanalog controlled moog drives, and I'm sure many times more responsive.
    Will have to look up PID tuning tips again.
    b.
Page 2 of 2 12
  1. Snap Grid
    By harlen.shaw in forum BobCad-Cam
    Last Post: 10-07-2011, 12:41 AM
  2. Snap Grid
    Last Post: 10-05-2011, 03:55 PM
  3. Snap on Dimension
    By keith20mm in forum Dolphin CAD/CAM
    Last Post: 10-13-2009, 05:48 PM
  4. Snap-On consumables
    By Captain Midnigh in forum Waterjet General Topics
    Last Post: 01-06-2007, 08:22 AM
  5. Brushless DC servos VS. Brushless R/C motors
    By sp1nm0nkey in forum Servo Motors / Drives
    Last Post: 03-07-2006, 04:37 PM
