588,275 active members*
8,426 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
Page 39 of 91 2937383940414989
Results 761 to 780 of 1805
  1. #761
    35538
    I have two movies, but I'm not sure how to upload them
    YouTube.
  2. #762
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  3. #763
    Feb 2005
    829
  4. #764
    Jun 2005
    1730
    Wigit,
    AWESOME.... wow it really looks smooth.... not sure what you will cut at 1000 IPM, but that is a fantastic rapid speed. CONGRATULATIONS!!!
    Russ
  5. #765
    Jan 2012
    394
    good job, congrats
  6. #766
    After I got the Constant Velocity settings in Mach3 correct, the rapids were even smoother !
  7. #767
    Feb 2005
    829
    Widget are you talking about that stutter when it changes from one are quadrant to another? If so my jonescnc is doing the same thing. how did you stop that stutter?
  8. #768
    Quote Originally Posted by nlancaster View Post
    One of the settings in Mach3 is "Look Ahead", by default it's too low a number! Set it to 200 lines or more!
    Widgit
  9. #769
    Apr 2005
    1268
    Nice Job Eric!
    Another widgitmaster creation.
    What's your first cut going to be?
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  10. #770
    Thanks Bill!
    Only worked in the shop for a fey hours this afternoon, but I did get the Red & Green LED's to operate as needed!
    I used an "Ice Cube" relay & socket, it is a triple pole double throw switch with a 12-VDC coil.
    Now when I press the
    E-Stop button the green LED goes off, the VFD's contactor de-energizes, and the red LED goes on!
  11. #771
    35538
    On commercial machines, after releasing the E-stop, another button press is usually required to restore power. You don't want things turning back on as soon as you release the E-Stop button.
  12. #772
    Jan 2008
    1543
    I think most VFDs will require a new command when repowered after power being cut.
    Widgit: Is it all wired such that the estop is normally closed? I.e. the normally closed estop switch keeps the vfd contractor open and if you have a wire break or switch failure it will result in estop mode?
  13. #773
    Quote Originally Posted by pippin88 View Post
    Each E-Stop has two NC switch blocks, one goes to the breakout board, the other to the relay. The relay is then active, and the contactor is in a closed circuit. A power failure would open the contactor!
    As of today, the VFD is not connected, as I've been a little gun-shy because of the poor Chinese manual. A friend & fellow Zoner will be by tomorrow to help me figure it all out and get it powered up! As for the re-energizing of the VFD after E-Stop, well I'm not sure ??
  14. #774
    Mar 2004
    1806
    On mine, there is a setting that you can make to switch between "non resume" and "resume" power after an outage.
    The safe one of course is "non resume"
    Art
    AKA Country Bubba (Older Than Dirt)
  15. #775
    Today I removed the Z-Slide, and setup the mill to drill two deep holes for the work light wires. Then I milled two pockets in the end of the z-slide, then drilled & tapped some M3 holes to attach the LED's! Then I setup the z-slide on it's back, so I could put an intersecting hole on the inner surface. This way the wires will be behind the spindle motor, and plugged into a small Delrin block ( not made yet)! After deburring all the sharp edges, I installed the LED's, and temporarily hooked up the 12-VDC.
  16. #776
    Jan 2008
    1543
    Quote Originally Posted by widgitmaster View Post
    Sorry, poor phrasing on my part, I did mean contactor closed (power flowing to vfd). The way you have it wired sounds perfect.
  17. #777
    Can someone help me locate a current list of Mach3's OEM Trigger codes, I could not locate them on the ArtSsoft pages!
    Widgit
  18. #778
    Jan 2013
    306
    Is this what you are looking for?
    http://www.machsupport.com/Mach3Wiki...le=OEM_Buttons
    Steve
  19. #779
    35538
  20. #780
    YES!!
    Thank you, that's exactly what I was looking for!
    Widgit
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. 4-axis CNC-router, NEMA23 steps, Gecko 540, Water cooled spindle
    By Vaffel in forum CNC Wood Router Project Log
    Last Post: 10-18-2010, 08:54 PM
  5. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
