Hello.
I have a problem with a lathe SQT-28M, T PLUS MAZATROL control.
The battery is depleted.
I have reset according to the manual, loaded the machine parameters, tool data, offset, cutting conditions, conditions of material, data plate ... etc.
problem:
When I run the program in automatic stays in standby mode in the initial cutoff and as much as I press the start key cycle, the system will not work. The spindle is rotating at a low speed.
You could tell me that it could be happening?
Could you send me some information to solve this problem.
Best regards.
