587,434 active members*
3,296 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > HY02D223B 2.2KW Spindle VFD - bad soldering?
Results 1 to 2 of 2
    Nov 2013
    9
    Hi guys
    The latest part for a CNC router build has just arrived and upon pulling it appart and inspecting the circuit board I have discovered one MCU with four of the legs bridged by solder.
    The MCU in question is on the top PCB, below and to the right of the display / control socket and ribbon cable. It has 13 legs a side (smallest legs of any chip on that board) and the two pairs of pins connected are the very last on the bottom side and the very last on the right side. Could someone please wip the cover off theirs and let me know if its the same? If not I'll jump in there with a soldering iron and separate the two. To be honest it doesn't look like those pins are being used and the VFD powers up OK (haven't programmed it for the spindle yet) so probably nothing but I would rather be safe then sorry.
    Thanks in advance!!!
    Nov 2013
    9
    Decided to crack out the soldering iron anyway: seems the pins cannot be separated (sitting on the same traces?) so I will leave them as is unless I run into problems in the future.
  1. HY02D223B Spindle acceleration (E.OC.n)
    By rkaasa in forum Phase Converters
    Last Post: 02-13-2021, 08:09 PM
  2. HY02D223B VFD
    By Dave Rothermel in forum Phase Converters
    Last Post: 11-21-2014, 02:12 AM
  3. Huanyang HY02D223B goes POP!
    By stevespo in forum Phase Converters
    Last Post: 09-26-2009, 08:12 PM
  4. Spindle speed at 25% on HY02D223B
    By Georgie in forum Phase Converters
    Last Post: 09-11-2009, 03:36 PM
  5. HY02D223B and GDZ-10 PLS HELP
    By 15mgtar in forum DIY CNC Router Table Machines
    Last Post: 08-21-2009, 06:32 AM
