588,453 active members*
5,779 visitors online*
Results 1 to 6 of 6
    Jul 2005
    236
    Case Hardening
    Has anyone found something to clean a part after case hardening it? Something that will work quick.
    Aug 2005
    1622
    Quote Originally Posted by larry53
    A sand blaster, wallnut or plastic media?
    If it was required to maintain the finish, cased in a vaccum furnace prevents most of the scale.
    I'd be wary of acid etching.
    DC
    Jul 2005
    236
    case hardening
    Thanks for the reply,however I am a small shop,I only want to clean up the part without using a brush if possible.
    Aug 2005
    1622
    Ultimately you will need to decide on what finish you expect or can live with. Then go from there.
    Wire wheels clean up scale nicely. Scotch brite pads do ok too.
    The size and shape of the part may limit some choices.
    DC
    Mar 2005
    1136
    are you doing your own? place i send mine to always runs it through the sand blaster. whatever nasty stuff is in the solution they soak it in can hang around become stuck in holes, crevices etc. if they don't get this crap out, i've found it makes things rust like crazy.
    Jan 2006
    51
    It depends on what you're case hardening, but if you coat it with soap first it will have a tendancy not to scale. Works well with O2
