588,289 active members*
4,759 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Programming a cone on a vertical machine centre
Results 1 to 5 of 5
    Nov 2013
    78
    Hi guys I've got to try and machine a cone from 38mm down to 35 mm on a victor v centre fanuc control I've tried using a form tool but alarms out is there any alternatives I.e single point with a boring bar can someone show me how to program this please !or can I interpolate a smaller cutter to achieve this please help!
    Using Tapatalk
    Feb 2007
    314
    wath is the alarm? did you try with a cutter that have the same taper than the cone to machine?
    Nov 2006
    227
    I cut cone/funnel shapes with a vertical mill often. You can use a boring bar, but I prefer a ball nose end mill
    Nov 2013
    78
    Yes the cutter was size on size and didn't like it so I need a program to use a smaller cutter I.e a ball nose cutter
    Using Tapatalk
    Jan 2006
    2985
    With a ball nose it is as simple as cutting a circle, move a bit in Z, then cut another circle, a bit bigger or smaller than the last. Keep stepping down (maybe .010" or so, depends on ballmill size and your required finish obviously) until you get the whole cone.
  1. Z axes zero Deckel Maho DMC 50V Twin Pallet Vertical Machining Centre
    By seed247freek in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-10-2012, 09:16 PM
  2. Replies: 7
    Last Post: 12-09-2010, 07:36 AM
  3. Gear Hobbing using Vertical Machining centre
    By gajjarcnc in forum Uncategorised MetalWorking Machines
    Last Post: 10-26-2010, 04:25 PM
  4. Programming a Cone / Taper
    By jpcaputo in forum Fadal
    Last Post: 08-12-2010, 12:58 AM
  5. Chevalier Vertical Grinding Centre
    By ben_heinman in forum Fanuc
    Last Post: 03-31-2007, 02:25 PM
