Quote Originally Posted by samco View Post
Some screen shots would help troubleshoot. one thing that probably isn't documented very well is currently if you program G64P.005 with no Q - it assumes Q.005. So if you want no naive cam detector - you would program G64P.005Q0 (there have been arguments about this off and on) but you have the control to tell linuxcnc exactly what you want. (once you know the secret hand shake )
sam
Well that's some info... Should I set q to zero to turn it off? I can see this as a possible issue. I'll test that tonight.
