588,197 active members*
4,519 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Alternatives to precise soldering - conductive plastic?
Results 1 to 6 of 6
    Feb 2005
    23
    Hi
    I wanted to ask, is there a way to connect electrical components without soldering.
    A silver paint for pcb trace correctures is easy to get - but can it be dosed precisely and will it hold the components on pcb?
    What about the conductive plastics - is it possible tu buy it somewhere, and is it conductive enough?
    Here is webpage that mentions condutive plastics(Polyaniline, Polyethylenedioxythiophene) (the site is about organic LEDs, by the way, is ti possible to get these light emitting plastic too?)
    http://www.ewh.ieee.org/soc/cpmt/pre.../cpmt0401a.pdf
    1695
    Why? Soldering is easy, durable and inexpensive.
    Feb 2006
    102
    a quick Google search for "electrically conductive epoxy +soldering" turns up
    http://www.sra-solder.com/epoxies.htm
    I think the best way to dispense would be with some sort of syringe.
    Read Carefully some epoxys for electronic work are THERMAL Bonding type for
    attaching heatsinks to chips, while they do have some metal in the content
    they are not intended to be highly electrically conductive, actually quite the
    opposite so as to prevent shorting.
    Mike_L
    Dec 2005
    3319
    H500: I thought the same thing until I thought about someone trying to solder something to paper, plastic or perhaps a hydrogen filled balloon - strange ideas but these are strange times......
    Feb 2006
    102
    Quote Originally Posted by NC Cams
    Soldering to a hydrogen filled balloon. . .
    Perhaps using a propane torch ?
    Way Cool, I want to watch . . . from very far away.
    Got any video?
    Mike_L
    When I was younger I thought I knew EVERYTHING,
    NOW, the older I get the more I find out I don’t know!
    Sep 2005
    12
    solder it dude.......if you have mass projects and looking for short cuts......contact volenteer circuits in bells tennessee....pcb manfacturers and wave solders
