588,311 active members*
5,076 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Post processor for EMC
Results 1 to 16 of 16
    Feb 2009
    9
    Which post processor should I use for generating code for LinuxCNC/EMC?
    May 2007
    428
    Hi Cboyce,
    On the new site (www.dolphincadcamusa.com), you'll see the post processors tab on the left side menus at the bottom. If you go into the PP page, you should find the EMC.
    Dolphin CAD/CAM Support
    Feb 2009
    9
    Hm, I searched for 'EMC' on the Dolphin Partmaster Post Processors page but the closest I found was one labeled "Emco TM 02 Milling machine with EMCO Controller". Am I looking in the wrong place?
    May 2007
    428
    If I am not mistaken, I am pretty sure that the Sherline machines use the EMC.
    Try the Sherline Table Top Mill. Post name- M_EMC 16Jan07.
    If that post works or is close, we can rename it. If it needs any tweaks, just le us know.
    Feb 2009
    9
    I'll give it a try, thanks for the quick response!
    May 2007
    428
    NP. If it needs any changes, email us at [email protected] so we can have it routed to the right person.
    Feb 2007
    592
    Quote Originally Posted by Dolphin USA View Post
    Sherline used a modifed version of what is now refered to as EMC1. This is several years out of date.
    EMC2 (v2.2.8) is the current version. It does all sorts of things not even dreamed up when the original EMC was in use.
    Dec 2003
    259
    Like what ?
    Most of the entry level post processors are very simple and share many features.
    Mach3 is based on EMC as regards a lot of it's core operating system. Both are also closely related to the Fanuc F6 controller as well.
    I post for two controllers, the old DOS Ahha controller and Mach3 and have custom PP's for both but other than two lines in the start up routine they are identical in output.
    If I edited these two lines either way I can use either G Code file on either machine. Both these posts support 4th axis so either try a couple of differnt post to see what it spits out or get a list of commands that EMC2 supports and list them here.
    John S.
    Feb 2008
    52
    What post processor do I use to output a lathe job to EMC2?
    Thanks!
    Goose
    Feb 2008
    52
    Re: Post processor for EMC
    Hi...
    Since my last post I have bought the Dolphin software package and I'm attempting to set it up for first use. I too cannot find the post processor for my Sherline Lathe.
    The M_EMC 16Jan07 suggestion above guides me to a broken link.
    Any other suggestions please and thank you.
    Goose
    May 2007
    428
    I have attached it, you just need to unzip it.
    IMPORTING POSTS
    Having received a new or modified post processor, you will need to import it.
    To do this double click the PartMaster Post Processor icon from your desktop, from the top toolbar choose Import
    and browse to the folder where the modified post processor was saved.
    When the file has been imported you will see the contents in the display area, next choose Compile from the top toolbar to create the .ppx file.
    The new post-processor is now ready for use. Close the post-processor by using File > Exit.
    When you next run DCAM the post processor will appear in the drop down list along with all original posts.
    Feb 2008
    52
    Great! Thank you...
    I imported the file into the Post Processor module with no trouble. I can't however select it in the lathe module as the selection box appears to filter on the suffix 'T_' as opposed to 'M_'
    I'm sure the Mill & Turing PP's are different but just for fun I copied it, renamed it with a T_ suffix and successfully compiled it however I get an error immediately afterwards:
    The Post-processo "T_EMC_2_04JUN12 - Copy" is V10 or earlier, the current PartMaster Dcam is V12.
    There have been modifications to the way in which Dcam Turning generates the NC program.
    Please contact [email protected] to obtain an update.
    Goose
    May 2007
    428
    Give this a whirl.
    Attached Files Attached Files
    Feb 2008
    52
    Thank you sir, installed without issue.
    My first job has some issues however seemingly not with Dolphin but the output stage which I'll get some help for directly from Dolphin.
    Cheers
    Nov 2008
    79
    Ok, so I took the the file M_EMC_2_04June12_V12 and renamed the prefix to T just like V8goose did. I then tried to post process a lathe file and got the error (see attachment) that the V12 file was actually a V10 file. So what gives? How do I get a Post for LinuxCNC/EMC?
    Thanks,
    John C
    Nov 2008
    79
    Rodney sent me two new posts. One for turn and one for mill. they seem to work fine.
    John C
  1. Post processor
    By reedmiles in forum BobCad-Cam
    Last Post: 12-14-2007, 06:19 AM
