587,784 active members*
2,610 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo motor with build in drive
Results 1 to 10 of 10
    Sep 2012
    45
    I am looking for a cheap servomotor for an belt driven XY table, used at a lab for dispensing liquids. I don't want the noise from steppers, since it will be used in a lab were people are sitting all day. I did a search and came across these servos with everything build into them (not the first 4 motors!):
    Encoder DC Servo : Robokits World, Easy to Use, Versatile Robotics Kits...
    Has anybody tried using these kind of motors or can comment on them for my use? They are really cheap and i was also wondering if they could be used when retrofitting my BF20 mill.
    But they do not seem to have any tuning for the PID loop (if such thing is present within them), which could be critical for make sure that it is in position on time. Bear in mind that this is not an issue with the XY table for the dispensing machine, since it only have to settle within an area of 1x1 cm.
    Any alternatives to these motors with the Nema 17 ore 23 form factor, that are not industrially priced?
    I could go for a drive that are not build in, but the only thing i can find are the really great, but also kind of expensive gecko drivers. Any cheap alternatives?
    Dec 2003
    24220
    I would want to know a little more on the command/SW end of things, it does not seem to go into these details?
    Al.
    Albert E.
    Sep 2012
    45
    In the manual it says DIR and STEP accepting 3.3v and 5v as logic signal. I will be using an arduino for control, so in that aspect it should be perfect
    Mar 2010
    8
    I have the same "problem", I am having 24V 5A Dunker servo's (GR63X55) with encoder . Also for a BF20 mill and do you have an answer if it's possible to use these servo's?
    Thanks , Hans (Netherlands)
    Sep 2012
    45
    I am not yet in the process of ordering these motors yet, but when/if i'll do i will of course notify you of my results Nobody else in here who know of these motors?
    Mar 2014
    26
    Re: Servo motor with build in drive
    Sep 2012
    45
    Hej Robbie, thanks for the link. They could interesting depending on the price. Do you have any information regarding their prices?
    Mar 2014
    26
    Hello Palmhoej,
    I know the MSRP is way high, I wave bought 4 brand new units (CM1-C-23L20) of E-Bay over the last two months from different sellers, for around € 100,- per unit.
    they are listed regularly.
    Regards,
    Rob.
    Sep 2012
    45
    Thanks for your reply. I have actually just ordered one from robotkit, but if they don't work i will try yours. I will of course brief you on the motors from robotkit.
    Mar 2014
    26
    check this 1 Cool Muscle Rohs Servo Motor CM1-C-23L 20C M5 | eBay
    I have bought two units from this seller for € 220,- inclusive shipping.
    Regards,
    Rob
  1. Servo Drive AC + servo motor for car steering wheel simulator
    By yusukeand in forum Servo Motors / Drives
    Last Post: 01-10-2014, 09:06 AM
  2. Replies: 5
    Last Post: 08-29-2010, 04:09 AM
  3. Servo motor drive
    By IanH in forum CNC Machine Related Electronics
    Last Post: 06-09-2008, 06:35 PM
  4. Sell Servo Motor, Servo Drive by GSKcnc.com from China
    By salecnc@hotmail in forum News Announcements
    Last Post: 06-03-2008, 08:55 PM
  5. need servo motor drive
    By Karl_T in forum CNC Machine Related Electronics
    Last Post: 11-28-2005, 04:37 AM
