588,342 active members*
5,104 visitors online*
Results 1 to 9 of 9
    Oct 2007
    25
    gantry vibration
    I have a kg1414 from k2, and for the most part I have been happy with it. I am using it to make some pretty delicate cuts, and the vibration in the y axis (large axis that moves the gantry) is affecting the surface of those cuts. The vibration is definitely not from any cutting process. It is the same when not running the spindle, and the cuts are extremely light on very soft material.
    These vibrations would probably go unnoticed for most woodworking applications, but they have forced me to slow down my process considerably. Any advice that anyone can give me would be greatly appreciated!!
    (The kg1414 y axis uses square rails, one on each side, attached to an aluminum extrusion frame)
    35538
    Re: gantry vibration
    Is it an audible and or visible vibration, or just something that shows up in the cut quality?
    Oct 2007
    25
    It is visible if you look at the very top of the z axis during a high feedrate move. You can also feel a vibration in the table. The sound of the gantry moving does have a bit of a rumble to it, but no loud noises anywhere.
    35538
    Is it in a particular spot, or the entire length of travel?
    Oct 2007
    25
    The vibration seems to be in the entire length of travel, and random, not a regular oscillation but more of a rumble.
    Apr 2006
    3498
    What is the acceleration set in the software? what software is being used to drive this machine? Seems to me the base is not supported well at all feet.
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Nov 2007
    2466
    Kahlid,, good to see you,, some were at Aspire Camp askng about you and hoping all was well ! good to see you posting
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Oct 2007
    25
    The acceleration doesn't seem to have any effect on the vibration. It is running the kmotion (dynomotion) software. The machine comes with rubber mounts, and blt holes along side the rubber mounts. I have it bolted down to the base of an enclosure made of 80/20 extrusions. Any suggestions on mounting?
    I feel like there shouldn't be much vibration in the first place, no matter how it is mounted, however the rubber feet are far from a precision item. I guess it is possible the frame is being torqued slightly by different pressures on each of the rubber mounts?
    35538
    Could be that it's binding, or possibly resonance in the motors.
  1. Fixed gantry vs moving gantry
    By scott0999 in forum DIY CNC Router Table Machines
    Last Post: 01-31-2014, 06:14 AM
  2. Router Gantry Beam strenght and vibration?
    By Knut in forum DIY CNC Router Table Machines
    Last Post: 12-27-2010, 06:29 PM
  3. Gantry vibration with rack and pinion
    By powerfade in forum DIY CNC Router Table Machines
    Last Post: 12-27-2009, 05:38 AM
  4. Gantry: planning to design moving open gantry
    By rdcd in forum Mechanical Calculations/Engineering Design
    Last Post: 11-14-2009, 10:52 PM
  5. Replies: 2
    Last Post: 09-15-2009, 05:09 AM
