588,585 active members*
14,078 visitors online*
    Aug 2012
    15
    Tools crashing after tool change
    I'm having a problem with my SCM NUM Routech Chronos Router
    After the tool changes, the tool is dropped to a level below the part, then tries to rapid through the part.
    I believe it either has something to do with the clearance level, or the plane height in the 'levels' category
    Any help would be appreciated
    Oct 2013
    153
    Re: Tools crashing after tool change
    if you can post your gcode . it would be more easy to spot the problem
    Aug 2012
    15
    Thanks for the reply, here is the gcode of the 2 operations that it crashed between.
    M11
    ( 29-MAY-2014 )
    L1=+20 (RIGHT PARKING)
    L2=-5070 (LEFT PARKING)
    L3=+25 (Y PARKING)
    (DYNAMIC PARAMETERS)
    G117 EC1
    E97300=1000 (FEED IN CORNER X AXIS)
    E97301=E97300 (FEED IN CORNER Y AXIS)
    E97302=E97300 (FEED IN CORNER Z AXIS)
    E97306=E97300 (FEED IN CORNER A AXIS)
    E97308=E97300 (FEED IN CORNER C AXIS)
    EG100 (PERCENTAGE OF ACCELERATION)
    (RESET DAT2)
    E60001=0
    E61001=0
    E62001=0
    E66001=0
    E68001=0
    (RESET DAT3)
    E60005=0
    E61005=0
    E62005=0
    E66005=0
    E68005=0
    G151 S0
    G52 GZ-200
    G0G52AC
    G0G52ZYL3
    G0 G52 XL2 YL3
    N3
    M224
    (LEFT ORIGIN)
    E60000=-4904.+336.*1000
    E61000=-1320.2+742.*1000
    E62000=-1015.+594.*1000
    E66000=0*1000
    E68000=0*1000
    M225
    G0X0
    (BJ 5AT)
    (5X-ParC-faces9)
    M31
    M110
    G151 S0
    T4 M6
    M3 M31
    S18000 M23
    E50004 = 179.15 * 1000 (TOOL LENGTH)
    E52004 = 20.0 * 1000 (TOOL RADIUS)
    C0D4
    G151 EU0 EV0 EW0 EA0 EB0 EC0
    G0 X383.471 Y-20.889
    G0 Z100.
    G0 C356.17
    G0 A99.235
    G0 X383.471 Y-20.889 Z100. C356.17 A99.235
    G0 X383.471 Y-20.889 Z-107.898 C356.17 A99.235
    G1 X386.767 Y28.353 Z-99.873 C356.17 A99.235 F2500
    G1 X356.951 Y29.802 Z-96.884 C356.17 A99.235 F3500
    G1 X341.012 Y30.214 Z-95.34 C356.626 A97.223
    G1 X326.07 Y30.534 Z-93.866 C357.114 A95.4
    G1 X312.122 Y30.764 Z-92.465 C357.579 A93.739
    G1 X299.384 Y30.908 Z-91.164 C358.063 A92.252
    G1 X286.435 Y30.983 Z-89.818 C358.576 A90.757
    G1 X274.484 Y30.981 Z-88.555 C359.041 A89.384
    G1 X262.537 Y30.909 Z-87.271 C359.525 A88.015
    G1 X250.616 Y30.762 Z-85.969 C360.024 A86.646
    G1 X239.671 Y30.56 Z-84.754 C360.53 A85.388
    G1 X228.732 Y30.292 Z-83.52 C361.045 A84.121
    G1 X216.81 Y29.926 Z-82.158 C361.495 A82.711
    G1 X204.84 Y29.485 Z-80.779 C362.015 A81.283
    G1 X192.944 Y28.979 Z-79.402 C362.516 A79.84
    G1 X180.071 Y28.353 Z-77.915 C363.011 A78.245
    G1 X168.202 Y27.706 Z-76.553 C363.41 A76.738
    G1 X156.045 Y26.972 Z-75.176 C363.877 A75.166
    G1 X146.189 Y26.319 Z-74.084 C364.313 A73.859
    G1 X138.339 Y25.755 Z-73.25 C364.542 A72.774
    G1 X131.497 Y25.23 Z-72.572 C364.755 A71.812
    G1 X125.653 Y24.754 Z-72.044 C364.932 A70.983
    G1 X119.831 Y24.252 Z-71.579 C365.041 A70.151
    G1 X114.997 Y23.812 Z-71.249 C365.096 A69.461
    G1 X110.346 Y23.368 Z-70.988 C365.142 A68.802
    G1 X106.74 Y23.008 Z-70.83 C365.134 A68.295
    G1 X103.629 Y22.686 Z-70.729 C365.115 A67.862
    G1 X99.812 Y22.276 Z-70.652 C365.067 A67.338
    G1 X96.011 Y21.85 Z-70.633 C364.983 A66.826
    G1 X92.227 Y21.406 Z-70.678 C364.863 A66.327
    G1 X88.932 Y21.003 Z-70.773 C364.725 A65.903
    G1 X86.119 Y20.646 Z-70.898 C364.582 A65.55
    G1 X83.318 Y20.278 Z-71.066 C364.418 A65.207
    G1 X80.532 Y19.9 Z-71.28 C364.201 A64.877
    G1 X77.762 Y19.511 Z-71.542 C363.935 A64.561
    G1 X74.92 Y19.097 Z-71.866 C363.658 A64.245
    G1 X72.101 Y18.674 Z-72.247 C363.293 A63.951
    G1 X69.4 Y18.253 Z-72.674 C362.879 A63.69
    G1 X66.728 Y17.824 Z-73.161 C362.406 A63.455
    G1 X64.09 Y17.385 Z-73.712 C361.873 A63.252
    G1 X62.137 Y17.05 Z-74.169 C361.431 A63.125
    G1 X60.21 Y16.712 Z-74.665 C361.055 A62.995
    G1 X58.517 Y16.407 Z-75.142 C360.572 A62.935
    G1 X56.847 Y16.1 Z-75.652 C360.084 A62.895
    G1 X55.201 Y15.79 Z-76.198 C359.599 A62.875
    G1 X53.583 Y15.477 Z-76.78 C359.089 A62.887
    G1 X51.995 Y15.163 Z-77.4 C358.492 A62.961
    G1 X50.44 Y14.849 Z-78.058 C357.932 A63.054
    G1 X48.92 Y14.533 Z-78.757 C357.361 A63.191
    G1 X47.439 Y14.218 Z-79.496 C356.697 A63.421
    G1 X46.001 Y13.905 Z-80.277 C356.107 A63.669
    G1 X44.608 Y13.594 Z-81.1 C355.517 A63.978
    G1 X18.929 Y7.775 Z-97.37 C355.127 A64.223
    G1 X15.105 Y-37.087 Z-75.626 C355.127 A64.223
    G0 X15.105 Y-37.087 Z100. C355.127 A64.223
    G151 EU0. EV0. EW0. EA0. EB0. EC0.
    G0 Z200.
    G0 GA0
    G0 C0
    G151 S0
    (BJ 5AT)
    (SCAN F)
    M31
    M110
    G151 S0
    G0G52ZYL3
    G0G52AC
    T11 M6
    M3 M31
    S18000 M23
    E50011 = 185.13 * 1000 (TOOL LENGTH)
    E52011 = 20.0 * 1000 (TOOL RADIUS)
    C0D11
    G0 X360.301 Y-35.65
    G0 Z250.
    G0 C0.
    G0 A90.
    G0 X360.301 Y-35.65 Z250. C0. A90.
    G0 X360.301 Y-35.65 Z-24.239 C0. A90.
    G0 X360.301 Y-34.65 Z-24.239 C0. A90.
    G1 X360.301 Y14.35 Z-24.239 C0. A90. F1500
    G1 X352.462 Y15.851 Z-22.989 C0. A90. F6000
    G1 X344.681 Y17.312 Z-21.776 C0. A90.
    G1 X337.864 Y18.569 Z-20.736 C0. A90.
    I cut the code short after the first lines of the 2nd operation as it never got that far
    Oct 2013
    153
    Doesn't see any difference between first and second operations . if the first tool runs without a issue then the second tool should not have one . all i can come up with is the difference in the clearance plane hight
    G0 X383.471 Y-20.889 Z100. C356.17 A99.235 -op1
    G0 X360.301 Y-35.65 Z250. C0. A90. --op2
    but i guess this is not a issue here ..
  1. ???Dropping Tools during tool change???
    By eddyindo in forum Daewoo/Doosan
    Last Post: 06-11-2013, 04:34 AM
  2. Replies: 0
    Last Post: 05-13-2013, 03:09 AM
  3. Bridgeport TC 2G drops tools at tool change
    By 4lo in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2013, 11:49 PM
  4. Tools sticking in Spindle at tool change
    By hatchmar in forum Okuma
    Last Post: 05-01-2012, 05:04 PM
  5. Crashing tools while learning am I worst than most?
    By Rich05 in forum MetalWork Discussion
    Last Post: 10-21-2007, 07:11 PM
