Re: C10 bob Optical Home Switch Wiring
Originally Posted by
DistortedDesign
OK mach is not registering the change when the beam is broken. My c10 power supply doesn't have a ground only pos and neg. Do I need to connect the c10 gnd to the 120v gnd on the main power supply?
Sent from my A500 using Tapatalk
Follow the diagram posted to connect the ground, it is accurate.
The C10 5 volt power supply negative is connected to the C10 ground / (GND)
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
