587,744 active members*
2,895 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > A2100 control touch screen fix
Results 1 to 6 of 6
    A2100 touch screen monitor repair. My arrow 500 tube type monitor died, Siemens said $3100 to upgrade to lcd. Lets see 200.00 for monitor,90 for touch screen 2 hours r&d, if all new parts, here is what i did. The touch screen is a Elo Touch , 5 wire resistive Accutouch, the standard is a 12.1" and you can buy this to fix the stock touch panel. I used a 15" LCD monitor I had around, Viewsonic vx500,15" LCD, removed the plastic case, installed a 15" Accutouch resistive touch panel and milled the plastic front housing to accept larger screen. I am now up and running with a 15" touch screen display, so easy to read and use. total cost monitor free, had one from an old computer, touch panel, $107.00 with freight., 2 hr of my time.
    Attachment 240396Attachment 240406
    Sep 2010
    1765
    Re: A2100 control touch screen fix
    NICE!
    Sent from my SCH-I535 using Tapatalk
    Feb 2011
    423
    Thank you!
    Sep 2009
    45
    The CRT died in our Arrow 500 (A2100,1998 model I think) but the touch screen was the strap-on type that just sits in front of the picture tube. I just bought a 12 inch flat screen monitor which was probably meant for a cash register or something and strapped it in the with two bands of perforated plumbing strap (Yes, I AM the true mechanic) and re-calibrated the touch screen. No modification to anything, cost was around $120. I also replaced the bulging rear cover with a flat sheet aluminum panel so the operator can store snacks in the recess behind the monitor. But your way was cool too.
    Bob:
    I was going to do what you did, but while using the 15" screen hung in front of the old one i got used to it being easier to read. Old eyes/ bifocals, so I went with the 15" fitmentand the small mod to the case. I also used a flat plate on the back of the enclosure. one note case is much cooler now.
    scott
    Jun 2004
    511
    Hello,
    Where did you buy the touch screen?
    Thanks!
  1. Acromatic 950 Touch Screen Retrofit - No Response From Touch Screen
    By csokoll in forum Controller & Computer Solutions
    Last Post: 05-27-2014, 09:41 PM
  2. Cincinnati Sabre A2100 Touch Screen
    By DRB4 in forum Cincinnati CNC
    Last Post: 11-15-2011, 03:10 PM
  3. Display and touch screen for OKUMA control
    By Omega71 in forum Okuma
    Last Post: 05-11-2011, 06:31 PM
  4. Replies: 6
    Last Post: 07-13-2008, 11:28 PM
  5. A2100 control touch screen problems!
    By a_davies616@hot in forum Uncategorised MetalWorking Machines
    Last Post: 04-19-2007, 06:44 PM
