587,999 active members*
2,107 visitors online*
Results 1 to 2 of 2
    Sep 2005
    166
    Hello CNC-community
    I’d like to change dead colors of my monitor. Black background is dead in the long run *ggg*
    So I’d love to know how you change your settings!
    Regards, Josef
    <!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--coloro:#800080--><span style="color:#800080"><!--/coloro--><b>Nichts ist unmöglich es dauert nur 5 Minuten länger</b><!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><br /><br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro--><b>mein Brötchengeber :-))</b> <!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro-->www.sebra.at<!--colorc--></span><!--/colorc--><!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec-->
    Nov 2007
    368
    Hi
    I believe you have to go to the additional functions. There’s color setting somewhere.
    You van change the colors for each monitor separately there.
    Primary I also had the graphic monitor in black with yellow lines. Then I changed it into grey (because white is too bright) with black contour lines and red tool path lines (dot lines)
    Auten
