603,316 active members*
2,930 visitors online*
Results 1 to 3 of 3
    I have to drill into a 18 solid material with a D8 drill, then mill an oval with a D6 miller.
    It has to be in DIN, and on a LB 3000
    Many thanks in advance
    Regards
    Jun 2008
    527
    What exactly do you want to do?
    Mfg MORI<br /><br /><br /><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto--><b><u>“Armselig der Schüler, der seinen Meister nicht übertrifft“</u></b><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc-->
    The LB3000 EX is only delivered in series standard with a X and Z axes.
    What options can you name?
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
