603,316 active members*
2,103 visitors online*
Results 1 to 3 of 3
    Good morning
    Can anybody tell me why the pockets are always too small with the contour pocket cycle G200 o(around 0,5 mm in X and Z direction)?
    The isles are absolutely true of seize.
    Is there a kind of scaling factor or is the shift sequence not executed?
    I have programmed the contour data in the pocket myself and run it with G41.
    Results: all outer contours are correct
    Regards
    amedo-sts
    Oct 2008
    265
    Hello
    Are you sure you are in the correct forum?
    I only know the G200 pocket cycle from Millplus- so from Heidenhain control systems.
    If you mean that one you can have a read about that cycle. It is well in the Millplus manual from the page 203 onwards.
    Maybe you could tell me what machine you have and what controller?
    Regards
    Dieter
    Dec 2001
    5090
    Hello
    Regards
    Dieter
    @ DJ-Bino
    It is correct here. The G200 existed already in PHILIPS control. Where do you think Millplus has that cycle from... as a follow-up controller of the PHILIPS 432 and 532.
    @ amedo-sts
    Could you display your program here and say if that problem also occurs when programming a contour without isle.
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
