Hello
My Heidenhain 530 doesn’t calculate the tool lengths correctly when processing vertically on B+90 (with cycle 301).
Why could that be? Do I need another M command ?
Please can anybody help me out?!
Thanks in advance
Hello
Thanks in advance
Hello
Is the cycle you are talking about a manufacturer cycle and what machine have you got?
The cycle 301 in not listed in the manual/ help of the TNC530. If it’s a manufacturer cycle then it should be listed and explained in the manual of the corresponding. If its not listed you can contact your manufacturer.
Maybe you are lucky and somebody in this forum is familiar with that cycle.
Usually it’s difficult to help when it comes to manufacturer cycles as you never know exactly how the manufacturer programmed it.
Regards Gerd
Wer das Konzept der Unendlichkeit verstehen will, muss nur das Ausma
Hello it’s a MATEK 6-axis MTV30 milling machine. I did not know the cycle either. I’m new there. I guess the cycle is additional.
Regards and thanks
