This is the first run.
Please note this is not the final version but the very first. I've used regular ball bearings on this one but I'll change the design due to hot bearings. Got some angular contact bearings on the way for the next version.
- ER20 chuck (shaft length: 100mm, shaft dia: 20mm)
- 3kw 24v water cooled brushless motor (1050kv)
- Cheap 200A ESC
- Cheap servo tester
- I'm using series wired two server PSU units.
