588,434 active members*
5,682 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Anyonehere using BobCad Cam v26 5 axis pro?
Results 1 to 7 of 7
    Nov 2011
    9
    Question Anyonehere using BobCad Cam v26 5 axis pro?
    Is anyone here using Bobcad v26 5 axis pro? Looking for general input good bad or otherwise-- the demo doesn't allow the user to create any tool paths to view what is possible.
    Before I lay out the bucks I want to hear the negatives (if any) and positives.
    Mar 2012
    1570
    Re: Anyonehere using BobCad Cam v26 5 axis pro?
    This part was programmed with V25 5 Axis Pro:
    Attachment 243868
    The multi axis versions of BobCAD CAM offers high end 5 axis tool paths. There are lots of options and does require the post and machine definition to be setup correctly. Once this is done, it comes down to when to use what options and why. Training is going to be very important if you haven't use a 5 axis CAD CAM system in the past. If you have, like mastercam, or surfcam, or GibbsCAM etc. You find the work flow and options to be very much the same.
    We have a number of users running our 4 and 5 axis software around the world. Everything from simple 3+ 2 to complex 5 axis impellers. So the question I have for you is, what is your application. Can you tell me more about the machines you are running and what you are looking to accomplish?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Nov 2011
    9
    Hi Al We are doing Cylinder head porting and combustion chambers. We also do part reproduction for vintage racing --5 axis would be handy.
    Nov 2011
    9
    Al is there a way to get a limited --Say 1 week 5 axis pro license?--This would allow me to explore the possibilities and see if it meets my needs
    Mar 2012
    1570
    What machine and controller will you be posting to and running on?
    Using 5 axis pro is more than just 5 axis programming. You'll have 7 surface based paths you can use in 3, 4 or 5 axis programming. Know that there are special options for porting.
    This video will help you understand how to use some of the surface based paths for 3 axis cutting.
    Al DePoalo
    Mar 2012
    1570
    One of the options has to do with the tool retracting though the center of a tube...
    Al DePoalo
    Mar 2012
    1570
    Here is quick review on 5 Axis Porting...
Name:	Excitement Using BobCAD.jpg
    Al DePoalo
  1. Replies: 32
    Last Post: 10-27-2013, 04:30 PM
  2. Replies: 1
    Last Post: 08-24-2013, 11:51 PM
  3. 4 Axis Programming with BobCAD V25 4 Axis Pro
    By aldepoalo in forum BobCad-Cam
    Last Post: 07-30-2013, 08:52 PM
  4. BobCAD V25 4-Axis users. Go 4-axis Pro?
    By TonyW in forum BobCad-Cam
    Last Post: 01-05-2013, 04:30 AM
  5. Anyonehere own a shapegrabber?
    By carbidecraters in forum Digitizing and Laser Digitizing
    Last Post: 01-08-2010, 06:53 PM
