588,281 active members*
5,032 visitors online*
Results 1 to 2 of 2
    Jul 2004
    240
    Tool Radius Compensation Question?
    Greetings,
    First: I am very happy with the Kflop Control and all the support Tom has given me in the development of our new software... We are offering for sale now, BlueCNC4. Works great!
    You can see our New Product release on the home page of CncZone.
    I have been testing things, which are Gcode related. My tool length compensation works beautiful. However, my G40, G41, and G42 seem to only work and create a ".500" offset, no matter what my "default.tbl" file says. I change my setting in my program... in my offset setup. And there I have a place for the tool dia., and this is directly reflected in the "default.tbl" file... but it does not seem to get to the controller.
    Does not the Kflop reference this file directly? For the dia. info. for the cutter? To use for tool compensation?
    Thanks in advance for your help.
    Sincerely,
    - Jeff Redington
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    Jul 2004
    240
    Solved: Tool Radius Compensation Question?
    OK, Solved...
    It was my mistake... I was not entering the D# with my G41... so it did not know which tool to use.
    G41 D1 (Use tool 1 dia. for Radius Compensation)
    Then your profile.
    I corrected this in my GCode file, and works as it should. I just assumed I had "screwed" something up.
    All is good!
  1. Tool nose radius compensation on SL-3a
    By cheenky in forum Mori Seiki lathes
    Last Post: 12-10-2012, 08:49 PM
  2. Tool radius compensation.
    By my-cnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2012, 07:37 AM
  3. Tool Radius Compensation
    By davidmb in forum Uncategorised CAM Discussion
    Last Post: 10-03-2012, 10:31 AM
  4. Replies: 10
    Last Post: 07-04-2012, 06:04 PM
  5. Help needed DynaPath 20 Tool-radius-compensation
    By dogstar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-14-2007, 01:42 AM
