588,342 active members*
5,025 visitors online*
Results 1 to 13 of 13
    6855
    How do you overclock a p4?
    How do you overclock a P4 CPU, through the bios?
    Apr 2003
    1079
    The easiest way is to increase the FSB speed (in very small increments), as the multiplyer for the chip is probably locked. I'm more of an Athlon man myself, so hopefully someone else (NeoMoses?) should be along soon!
    You'll find the limit pretty soon, when your PC no longer boots! Of course be aware that upping the FSB also overclocks the rest of the system, ie ram, pci and agp. There may be settings in the BIOS to underclock these areas in relation to your new higher FSB setting to promote system stability.
    6855
    Looks like I can't do it on my Dell, it's all locked.
    Apr 2003
    1079
    Whip the side off' the case, and see if you can find out anything about the motherboard. Try a google on your findings, sometimes it works.
    6855
    Wow what a difference! I'm running at abot 41deg C and my processer speed is at 2698mhz for a 2.3 gig looks like I can get to 3.2 if I get better cooling.
    Apr 2003
    1079
    That's a nice overclock! You may want to run some stability tests before you go for that 3.2Ghz though! If you have some games, play them. If you have some cad software, do some big drawings. Anything to stress the processor for a couple of hours should tell you if your PC will cope with the next stage.
    Apr 2003
    3578
    Paul take the time and ad some more cooling maybe even water cooling if you are going to push it to the 3.2 arena.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    6855
    I'm looking into a better fan system.
    May 2004
    4
    overclocking ?! what for ?
    Mar 2004
    190
    varies depending on individual basis..
    a) more speed for less price
    b) less noise for same speed
    Fer
    Apr 2003
    292
    Basically all you can do with a P4 is increase the front side bus (FSB). The multiplier is fixed. Depending on the rated speed of your RAM, you may have to play with some different memory dividers to max out the potential of the CPU. Once you're using good cooling, you can also play around with the CPU core voltage to get a little extra speed, but this is the point of diminishing returns.
    Make sure you are testing for stability with each successive overclock. Download Prime95 and run the torture test. It's a good way to see if you are really stable. You should be able to run over 48 hours of Prime95 without problems on a stable computer... once you've reached that, you can call your computer 'stable.' Nothing is more annoying than an unstable computer, so make sure you try it out after upping the clock speed.
    ufcio: overclocking ?! what for ?
    For added speed with a given computer system.
    Paul, www.overclockers.com and their associated forums are a great place to learn everything you need to know about overclocking.
    My name is Electric Nachos. Sorry to impose, but I am the ocean.
    http://www.bryanpryor.com
    Jan 2004
    35
    I agree, why overclock it. For the added cost you should just buy the faster cpu. I upgrade every 2-3 years and haven't overclocked since the 366 celeron. It was the only one that was a worth overclocking. The added speed isn't worth stability.
    My thoughts,
    Chris
    Chris
    Apr 2003
    292
    My thoughts,
    Chris
    Here's the basic idea: Buy a lower cost processor and put a little more money into the cooling system. You'll end up with a faster computer than had you bought the higher cost (speed) processor, plus a good cooling system won't become obsolete as quickly as the processor.
    Example: Today (May 3, 2004) you can buy a P4 3.0C for $220 or a P4 3.4C for $415. If you buy the 3.0C and spend ~$150-$200 on a watercooling system, you'll probably end up with a P4 running at 3.6 GHz or faster. The watercooling system will also be quieter than the OEM aircooling system with the 3.0 or the 3.4. That's the gist of the whole overclocking community.
