To do a counterbore, select the hole (either a circle or the point in the middle will work) and use a drilling operation with the appropriate-sized tool set to the depth you want to bore to. To do a chamfer, select the edge you want to modlfy and set up an engraving operation with a V-shaped tool that is lowered to the correct position, which depends on how much you want to take off.
