588,246 active members*
5,759 visitors online*
IndustryArena Forum > CAM Software > CamWorks > NEED HELP ON MILLTURN WRAP FEATURE
Results 1 to 6 of 6
    Nov 2004
    70
    hi we have a kia 4 axis millturn lathe need help on the how to cut wrap engraving or
    open profile.
    Mar 2008
    111
    Re: NEED HELP ON MILLTURN WRAP FEATURE
    First of all you will need a SW coordinate system in the correct orientation, this has to be utilised in your setup, then a post configured for wrapped features.
    Then as long as your feature is actually considered wraped (the centreline of the edges must pass through the centre point)
    I think to be honest that's more of a 4 axis simultaneous feature
    Dec 2010
    126
    That's definitely a wrapped feature. I would start by opening the CAMWorks manuals and finding the section of wrapped features. It walks you through how to do things like that. It takes a lot of patience but works well once you have it figured out. If you can't figure something out by reading the manual, come back here and ask more specific questions so we can help.
    Good luck!
    Nov 2004
    70
    i just try to milturn ( on the lathe ) run to ball em wrap simultaneous wrap feature around feature hight light in yellow, i had try wrap engraving and ( open profile ) picking long the edge
    and it not working , cause the wrap it in 3d, i don;t see camworks have that option
    Mar 2008
    111
    You'll need to do it is a multiaxis feature, with a 5 axis tool path limited to four axis
    Nov 2004
    70
    thanx you jame5m28. finally i got it to work like you said 5 axis limit to 4 axis Click image for larger version.
  1. Replies: 8
    Last Post: 07-18-2012, 10:51 PM
  2. Dill feature without center drill feature
    By LockTech in forum BobCad-Cam
    Last Post: 08-25-2011, 02:38 PM
  3. MillTurn Memory Problem
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 11-24-2009, 11:10 PM
  4. hyperMILL millTurn module
    By Alan L in forum Hypermill
    Last Post: 01-02-2007, 02:33 PM
