not out yet...but will drop next week...
Big Chipin, spreading tha cheese, I be Big Chipin for days!
Just the things from that video had me pretty fired up. Big changes at a fundamental level. Here's hoping for a smooth launch, and a good experience with it!
Luke
"All I'm trying to find out is the fellow's name on first base" -- Lou Costello
Raf,
Yes you can scale XYZ. You can scale all together or individually.
Are finally going to get pipe thread milling?
3D Connextion is now compatible...
I'm all for the 3D connextion move. Parametric will be nice, I wonder if it will have the ability to do mdf door profiles like I want.
Forrest
Parametric will be an interesting addition. Now that I have a tiny bit of Solidworks under my belt, I've learned a bit about design intent. A drawing can "explode" into nonsense if you aren't careful. A change to an early stage of the model can be troublesome at times.
I also wonder again about compatibility with previous files/models. Will my drawings open without issue in V27?
CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
