588,159 active members*
4,991 visitors online*
Results 1 to 6 of 6
    Apr 2013
    34
    Fanuc Drive Alarm
    I am trying to repair a card. The card alarm was: A
    Now I want to check the alarm without connecting this card to Machine.
    As far I know there is a port to give 24 Voltage to show the alarm.
    So, which port we should connect 24 voltage to display the alarm. There I see two port: C0P10A, C0P10B
    Attachment 248342
    Jul 2013
    24
    Re: Fanuc Drive Alarm
    HI,
    C0P10A is your output
    C0P10B is your input
    In order to power with 24 vdc, you would only need C0P10B
    Hope this helps.
    Jade York | (888) 939-7250 | www.repairzone.com
    "Your Servo Motor and Industrial Electronics Specialists"
    Apr 2013
    34
    Which port is positive?Upper or lower?
    Jul 2013
    24
    Input for the low voltage is CXA2B, however the card will not power up out of the amp.
    A-Alarm= Inverter Alarm on N axis (DC link or IPM)
    If you need any further assistance it would be best to send your unit in for a proper evaluation and diagnosis. You can contact Repair Zone through there website for a quick free quote. Servo Motors and Electronics - Buy or Repair | Repair Zone
    I hope this information helps
    Apr 2013
    34
    I have alreay contacted. But how can check the alarm now wothout connecting the card to machine.
    Jul 2013
    24
    At this point troubleshooting on your end with out schematics or manuals, may be more troublesome and pose a higher risk of further damaging your unit.
    In order to successfully troubleshoot your Fanuc drive, we would need you to send in your full drive, card, and the bottom end. We would then place it in our simulated system to further diagnose your alarm code.
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. Fanuc ac spindle drive alarm#4
    By movick_25 in forum Fanuc
    Last Post: 01-16-2012, 04:45 PM
  3. fanuc spindle drive alarm no-10
    By r_mahesh77 in forum DNC Problems and Solutions
    Last Post: 09-12-2007, 04:22 PM
  4. Fanuc ac spindle drive alarm 01
    By suresh patil in forum DNC Problems and Solutions
    Last Post: 08-08-2007, 08:37 AM
  5. Spindle drive alarm in fanuc 16 ta
    By miguisu in forum Fanuc
    Last Post: 02-20-2007, 05:12 PM
