Originally Posted by
mactec54
I would think that how ever they were shipped, is up to the how well the shipping system is working, as to how long it takes in transit
I have only seen this same problem when the wiring is incorrect, this will cause the same problem that you are having, motor wiring to the drive is important, also the input power wiring, there is no protection for incorrect wiring
They load the software, it is a very simple process, you can't have one that is good, & the next one is bad, it does not work like that, did you return your other drives, as they will be able, to see what has caused this problem, for sure
Are you using the 48v Drives, when testing or doing any changing of plugs wires Etc make sure the power is off, I will be talking to them today so will ask about your drives
