588,205 active members*
3,985 visitors online*
    Jun 2011
    14
    Mach3 PCI Parallel Port Card Problem
    because my old pc crashed I had to buy a new one for my CNC. It's a Dell XPS420. Since it has no parallel port I also bought a parallel port card (from Logilink). I installed Mach3 and the card. The i/o range started from CCD0 so I set the port in Mach3 to 0xCCD0. So far everything went fine, but the software doesn't spin my steppers. The steppers are getting energy (they are strongly fixed at their current position) but I'm unable to rotate them. The operating system is a WindowsXP 32 Bit. The driver for the parallel port card does not allow me to set the mode to ECP or EPP but it's specified on the datasheet of the card. All pins are set correctly.
    Any ideas?
    Greetings
    Cornelius
    Jun 2011
    14
    Re: Mach3 PCI Parallel Port Card Problem
    Solved...
    Jun 2010
    4262
    Solved?
    You might explain how!!!
    Cheers
    Roger
    Jun 2011
    14
    The parallel port card does not seem to be compatible to Mach3. I got a new one from a friend and with it everything works fine.
  1. Parallel port pci card
    By Dylwad in forum PlasmaCam
    Last Post: 08-07-2013, 02:15 PM
  2. Parallel port card??
    By skylanehku in forum Gecko Drives
    Last Post: 08-29-2012, 04:53 AM
  3. Parallel port add-in card.
    By Drools in forum Gecko Drives
    Last Post: 06-27-2012, 06:40 PM
  4. PCI parallel port card
    By Smooth90 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-13-2011, 05:17 PM
  5. Which PCI parallel port card?
    By bead in forum CNC Machine Related Electronics
    Last Post: 07-03-2010, 07:32 PM
