Im a novice at this at best but il try to explain best I can, the switch in the torch that Im tapping into does click when pressed so Im sure that its a contact closure. I have another relay comming off ebay thats a spst 4 connections on it. So sounds like the problem is that i cant use the solid state relay. However i have tried the 12 volt relay as well, just the basic automotive type with contacts.
