588,632 active members*
5,412 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Table top and tool touch up stone recommendations
Results 1 to 12 of 12
    Aug 2013
    980
    I have been using an old Arkansas stone to take burrs off my top but I would like something easier to use and better.
    Any recommendations on a stone that is good to flatten/de-but the top of the table and bottom of the vise?
    Also, my Tormach HSS boring tools need touching up. I have a good grinder but would like to use a smaller stone to touch them up. Any recommendations of a mfg. that makes good touch-up stones?
    CR
    Nov 2010
    291
    Re: Table top and tool touch up stone recommendations
    I use a stone as well and have a dia-sharp diamond sharpening card for carbide and touching up edges. What is wrong with your stones?
    Aug 2013
    980
    I only have the one which is long and skinny for sharpening kitchen knives
    It is hard to hold when I try to knock down my table. Plus it is a soft stone
    Jan 2007
    1332
    I use an 8" DMT DuoSharp diamond stone for all of my sharpening needs in both shop and kitchen, carbide and steel. DMT WM8EF-WB 8-Inch DuoSharp Plus Bench Stone-Extra Fine/Fine With Base - Sharpening Stones - Amazon.com The DuoSharp comes with a very stable base that can also be used as a hand hone with the built in handle. Also only water is needed not messy oil. BTW resurfacing that Arkansas stone is done the the DuoSarp diamond stone.
    Don Clement
    Nov 2013
    402
    I use one of these, and love it.
    Coarse and fine grit, all in one stone.
    $3.00 at Victor Machinery
    Feb 2009
    6028
    We use a round stone, about 5" diameter. Has kind of a grove around it to act like a handle. I'll see if I can get a name off one, I know there is one always at the Blanchard grinder.
    Jun 2006
    3063
    Quote Originally Posted by underthetire View Post
    Sounds like one that Tormach recommended a while back. It looks like it is a Norton JB74, 4-in OD x 1-1/2-in tall and different grits on each face. Forgot where I got mine, but Zoro sells them for $40 and it looks like McMaster-Carr sells the same thing for $22:
    McMaster-Carr
    Mine seems to work pretty well for taking burrs and bumps of the table.
    Mike
    Before buying from MMC, call and ask if that product is the Norton JB74. They don't like to call out manufacturer's names in the catalog but will supply detailed specs on request.
    Aug 2013
    980
    Thanks Mike
    That is the one I was looking for that I saw in the old Tormach video
    Thanks also for the MC advise
    Cr
    Quote Originally Posted by MichaelHenry View Post
    McMaster-Carr
    Mike
    Dec 2012
    161
    Related question, how do you clean your stones? After typing that I realize it sounds... wrong. But the question stands
    Aug 2013
    980
    I have been thining about your question and don't have any clue. I think this would be worth a call to Norton.
    Quote Originally Posted by FuriousGeorge View Post
    Oct 2011
    477
    Wash with mineral spirits/kerosene. Level and resurface with a diamond stone or silicon carbide paper on a flat surface.
    Nov 2007
    2151
    A small stone comes in handy for the t-slot faces. "a 1/2x3/4x4 stone used for tuning skis"
    I stone those faces before setting vise, and it helps the vise keys set and position cleanly.
    Seams like t-slot clamp systems burr those edges now and then or I ding them moving stuff around.
    md
  1. SINO YAG 750W laser metal cutting machine
    By sinowaterjet in forum News Announcements
    Last Post: 07-10-2014, 03:37 AM
  2. Advice for stone cutting tool in making bowdrill sets
    By danielcoyle in forum Glass, Plastic and Stone
    Last Post: 07-05-2014, 12:36 AM
  3. Stone engraving machine with Anti-rust table broad
    By Zhang Luying in forum News Announcements
    Last Post: 12-10-2012, 08:50 AM
  4. Need Recommendations For Rotary Table
    By DiyAddicts in forum HURCO
    Last Post: 08-10-2012, 04:36 PM
  5. Rotary Table Recommendations
    By gpettit in forum Haas Mills
    Last Post: 06-30-2012, 03:44 AM
