587,997 active members*
2,001 visitors online*
Results 1 to 9 of 9
    Jul 2012
    28
    CO2 laser in cutting metal
    Dear members ,
    My name is Costin and I'm from Romania
    I have some questions regarding metal cutting .
    I own a 170 watts CO2 CNC Laser machine and for some time something is troubleing me .
    Looking over the youtube I can see that other friends who also have a 170 or 150 watts co2 laser can cut maximum 2 mm steel and in my case i bearly make a burning mark on it.
    As I did some researches I found out and saw that their cutting head it's much different from mine .
    My cutting head uses a focusing lens 20mm diam at a focal lengh of 63.5mm
    and that machines wich can cut metal are using a bigger cutting head with cooling and using Oxigen .
    My purpose is to cut maximum 1 mm thick using my machine .
    I looked over youtube and found some videos in wich with the same power as mine can cut metal and can cut it very smooth
    I attached some links :
    https://www.youtube.com/watch?v=e9BvPeAmuvc
    https://www.youtube.com/watch?v=XDgKociyNVU
    https://www.youtube.com/watch?v=RRgB2YbQsWc
    I also found a similar cutting head on alliexpres but i don;t know if it is the right one
    High Power Two Bifocal CO2 Metal Laser Cut Head (With Cooling) Using for Metal or Thick Non Material-in Laser Equipment Parts from Industry & Business on Aliexpress.com | Alibaba Group
    Maybe you can give me an advice in what to buy and were to buy this kind of cutting head for solving my problem .
    Regards,
    Costin .
    Feb 2012
    387
    Re: CO2 laser in cutting metal
    This is Lucy from G.WEIKE, we replied your emails ,please check,not all 150-170w laser power can cut metal, there is special design inside, including the laser head, lens ,mirror,and auto adjuster etc
    Lucy Lee G.WEIKE LASER
    [email protected]
    Jul 2012
    28
    As I could saw from the youtube videos it was already clear to me that 150-170 watts co2 lasers can cut metal , the question in my case is if it is possible for my laser machine to cut metal too .
    Please explain what special design means to you .
    Lens : diameter , material , focal lengh
    mirrors : diameter , material other characteristics
    Laser Head (dimensions , material , intakes , nozzle )
    I must remaind you that my machine has 3 MO mirrors 25 mm diam .
    and the lens used is 20 mm with focal lengh of 63.5 mm
    REgards ,
    Jun 2006
    198
    It depends on the wavelength of your laser tube. If the wavelength is not correct you will never get it to cut metal. A vawelength of around 10.6um should be the correct wavelength.
    Jul 2012
    28
    on the tube specification it says that is 10.6um . Well how can I check if its ok ...The laser have been used for aproximately 50 hours.
    Dec 2012
    19
    If you want the 170w Co2 laser to cut metal, you just need a metal laser head, using the metal laser cutting head, you can cut the metal and non-metal smoonthy.
    this is our 150w laser cutting machine cutting 1.6mm stainless
    This is the machine's details:
    Attachment 256812
    More information: please visit:L1325s laser cutting machine
    www.laser-solution.com
    Jun 2006
    198
    Ohhh, yeah. And you need cutting gas. For steel you need Oxygen at low pressure, something like 0.5-1.5bar, and for stainless steel and aluminum, you need Nitrogen, at high pressure Something like 6-19bar.
    Hello In-WondeR,
    CO2 laser cutter for cutting metal, it requires high power laser tube and Oxygen gas.
    Usualy use Reci Laser tube Z6, 130w-160w, with Oxygen gas assistance, it can can 1.5-2.0mm stainless steel. Without Oxygen, it can cut 30mm acrylic.
    machine photo is sent to you. please see below:.
    Attachment 257004
    For more information or VIDEO, please feel free to contact with me.
    Wendy (Ms)
    ​Website: www.sukelaser.com
    ​Msn: [email protected]
    ​Email: [email protected]
    ​Skype: sukelaser5
    ​Mobile:86-18354118737
    ​Fax:86-531-85762139
    Hello Costin
    Good day
    if your purpose is to cut maximum 1 mm thick using your machine , your machine is no problem with Oxigen , but cutting edge have some burr, not very smooth,
    if you need high quality production , you need cut with special laser cutting head .
    Best regards
    Frank
  1. Metal laser cutting machine is easier to achieve diversification sheet metal
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-16-2014, 07:46 AM
  2. Thin metal laser cutting machine- CHEAPEST metal laser cutter
    By Gweikelasers in forum News Announcements
    Last Post: 03-06-2013, 10:08 AM
  3. Metal Laser Cutting compared with trational metal cutting way
    By ellalaser in forum News Announcements
    Last Post: 07-21-2011, 11:18 AM
