588,199 active members*
4,554 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Wiring 4 pin connectors for motors question
Results 1 to 5 of 5
    May 2013
    455
    Hey everyone,
    Happy Thanksgiving to everyone in the states.
    I am finishing up my electrical control cabinet, and I am at the point where I need to wire up my motor connectors permanently. I am using 4 pin motor connectors, and I am not clear how to attach my wires to the connector pins.
    The male side looks pretty straight forward, I can just push the wire in and solder it and it should hold well, but I am not clear on the female side at all. I suppose I can solder it there too, but I am wondering if there is a better way to do it?
    Here is a pic of both my male and female side where the wires connect. The male is on the left, and the female is on the right. Any suggestions would be helpful.
    Attachment 258550
    Nov 2009
    4415
    Re: Wiring 4 pin connectors for motors question
    That is a different tab than I am used to but it doesnt appear to be a tab for a spade or similar . I say solder it. After doing a few of these cnc projects and desiring the coolest of connectors, I have found that if the BOB has screw terminals it is better to just push the wire thru a grommet and skip the additional connector. Once up and running there is no need to disconnect steppers, if you do have to, unscrew the 4 wires. Or unplug the Phoenix connector on the board (which wont fit thru the grommet btw).
    A lazy man does it twice.
    May 2013
    455
    Quote Originally Posted by Fastest1 View Post
    Thanks, that is what I will do, just solder them.
    Yeah, for the BOB I am just pushing the wire in and tightening, seems fine. I went a bit crazy with connectors for my terminal power strips, but I think they are warranted there.
    I will post some pics of everything when I am done in my build thread.
    Oct 2004
    298
    I have some like that and I soldered them. I just took a small piece of heatshrink and slide it up the wire before soldering, so then I can slide it down and shrink it in place. It makes for a very clean connection.
    YouTube Channel: https://www.youtube.com/c/RobertCowanDIY
    AVRnj - they are both classed as 'solder bucket' ... It's normal to push the wire though the hole to provide a more mechanical fit, but as in this case there is often not enough room to then solder over the wire and as cowanrg says fit heat shrink. over the top.
    Lester Caine - G8HFL
    http://medw.co.uk - Home of electronics for the Model Engineer
  1. Replies: 3
    Last Post: 03-26-2013, 11:43 AM
  2. Encoder wiring connectors
    By SIMONSIGNS in forum Stepper Motors / Drives
    Last Post: 01-20-2011, 11:10 PM
  3. looking for good wiring quick connectors
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 02-08-2010, 06:49 PM
  4. motors connectors
    By dan dimock in forum CNC Machine Related Electronics
    Last Post: 03-02-2007, 11:29 PM
  5. Best type of quick connectors for motors?
    By pfarber in forum CNC Machine Related Electronics
    Last Post: 01-04-2007, 11:43 PM
