587,083 active members*
2,971 visitors online*
Page 20 of 25 101819202122
Results 381 to 400 of 493
  1. #381
    Nov 2014
    Re: X61500GT - New CNC-Carving Router
    I am thinking of buying the X61500GT but reading this thread scares me. I am totally new to this and all problems listed makes me think that better stay out of this. I need one for my business. Would like to see a complete post written by someone who knows how to do the setup and operation. I use SolidWorks 2014 and just now learning CamWorks 2014 I am not sure I can do what i want with this machine. I want to make parts in 316 stainless steel and would need to know if this can be done. I plan to use 0.5, 5 and 10 mm sheet and 25 and 35 mm mm round bar to produce forward controls for motorcycles. Can this be done with this machine? Attached is a rendering of the assembly.
    Grateful for any input from you guys. Can it be done and if so how?
    Attachment 258802
  2. #382
    Sep 2009
    1856
    I would not get this machine to do stainless steel you would be better of with a mill as stainless is hard as sh__ and the spindle is a high speed spindle the rpm required to cut stainless is less that what is required for the spindle to self cool.
    you could get one and change to a lower speed spindle but to cut 10 mm stainless it would take a very long time to cut it as you cant drive these machines very fast.
    so just save your self the pain and get a mill there are low cost options out there that will do what you wont all day every day
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  3. #383
    Jul 2006
    182
    Yup - this machine is a CNC router, ideal for wood, plastic and aluminium using light cuts. Mild steel or stainless requires a *much* heavier, *much* more rigid machine with far more torque, i.e. a milling machine.
  4. #384
    Aug 2013
    10
    So "notification received" on the DHL website is something I clearly did not understood, but now, 6 days later, it actually shows something useful. As in. "Shipment picked up" and "Departed facility". So either it was sitting at KL for a week twiddling its cables, or it had not arrived yet. Anyway. Progress. Christmas rush looms. "Fastway" couriers cannot deliver a couple of 3D filament spools ~20km in a day. Twiddling my own thumbs waiting for something to play with.
  5. #385
    Sep 2009
    1856
    we have the same problem over here with Fastway a week from 564km away sometime 2 weeks they are one of the worst
    [SIGPIC][/SIGPIC]
  6. #386
    Oct 2013
    104
    This machine should only be used for wood and plastic..in alu the head bend to much. If you are planning to mill some alu...use 1flute. Theyre built for higher rpms. 2flute and higher will just melt/rub into the flutes, destroying both part and tool. Use lotsa coolant.
    A 'router' is built for acryl and wood. A mill is built for metal.
    I have both and I started with a router...thinking i could make some cool alu parts..tool wear is ruining da biz on a router. Oh..and the last thing, stainless require about 1k-2k rpm. On the GT you will burn the motor with that speed.
  7. #387
    Sep 2009
    1856
    you can use coated cutters with routers cutting aluminium they cost a lot but they work well at very high speeds
    [SIGPIC][/SIGPIC]
  8. #388
    Sep 2014
    129
    You can use uncoated 2 flute carbide cutters with this machine
  9. #389
    Sep 2009
    1856
    correct but if you have your setting wrong they last about 10 seconds.
    I all ways use the coat cutters its harder to destroy them
    [SIGPIC][/SIGPIC]
  10. #390
    Aug 2013
    10
    Quote Originally Posted by daniellyall View Post
    Yeah? I went to their Facebook page to vent, and the "posts to page" section is a litany of "WTF Fastway, where's my fracken parcel?" Delivery guys throwing parcels over the fence, or leaving it in the driveway not even knocking on the door. Franchise gone wrong. My confidence in receiving the filament any time soon plummeted.
    - - - Updated - - -
    Is this kind of stuff summarised anywhere? And do you have a link to a supplier for these coated cutters?
    Thanks!
  11. #391
    Sep 2009
    1856
    I got them from trade tools
    [SIGPIC][/SIGPIC]
  12. #392
    Aug 2013
    10
    I don't mean to sound lazy but can you give us more info? I found tradetools.com but is that the store? Do you have a direct link to the cutters? As a complete newb this stuff is way over my head.
    Thanks!
  13. #393
    Sep 2009
    1856
    I use these ones as well Carbidenz 3mm 2 FLUTE CARBIDE ENDMILL
    [SIGPIC][/SIGPIC]
  14. #394
    Sep 2014
    129
    TiAlN coated carbide endmills are not good at high speed milling aluminium for several reasons:
    Aluminum Machining, Machining Aluminum, High Speed Machining | Radical Departures
  15. #395
    Sep 2009
    1856
    its quite funny that I have never had this problem
    [SIGPIC][/SIGPIC]
  16. #396
    Aug 2013
    10
    @4:45 this morning:
    Shipment has been given a release by Customs.
    Unless there is an adhoc exam or a stop by another regulatory authority the shipment will proceed to delivery
    :wee:
  17. #397
    Sep 2014
    129
    That is very good news aarondc!
  18. #398
    Sep 2009
    1856
    hope you get a good one
    [SIGPIC][/SIGPIC]
  19. #399
    Aug 2013
    10
    :nono:
    @07:46
    Shipment arrived at incorrect facility. Sent to correct destination
  20. #400
    Aug 2013
    10
    So the CNC has arrived. One ding in a corner of the bed of the CNC, lots of dents in the foam but I guess that's what it's there for. Covered in "REPACKED" DHL tape, and the boxes inside were opened :-/ One bolt missing from one of the stepper motor mounts which I find very annoying :-/ It looks like DHL went through the entire thing then just tossed the boxes, still open, back into the main box.
    It's all unpacked now, and I'm going to wait until I have the CNC-specific computer put together before I bother building this any further than putting the Y-Z gantry onto the bed and all the bits and pieces away in draws. The $40 second hand desk I bought to house it on is just right.
    Rather than clutter this thread with more mindless drivel, where's the best place to start my own thread to detail fixing the bits and pieces that need to be fixed (like the unshielded cabling, for example) before I even think about turning it on?
  1. Replies: 4
    Last Post: 02-12-2014, 01:17 AM
  2. LIMAC 4 head cnc router for carving
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 09-09-2013, 08:11 AM
  3. CNC Wood Carving Router
    By omnicnc in forum Omni CNC
    Last Post: 12-03-2012, 10:23 AM
  4. Foam Carving CNC Router
    By Alan_c in forum DIY CNC Router Table Machines
    Last Post: 05-26-2009, 10:59 PM
  5. Which CNC router for wood carving is good
    By CNCguy82 in forum Want To Buy...Need help!
    Last Post: 08-04-2008, 06:02 AM
