588,585 active members*
13,461 visitors online*
Page 2 of 2 12
Results 21 to 35 of 35
  1. #21
    Mar 2006
    18
    probe
    thank you very much.
    clave
    Quote Originally Posted by Hood
    The way it works is simple, the balls make contact with the copper and the space between the copper is bridged by the pins (which are insulated from each other). The pins are held against the balls by a spring and any side movement or end movement against the pin holder causes it to break contact with the balls and thus the circuit is broken.
    I adjusted my first one by means of the four setscrews you can see sticking out the side of the metal holder and got it true to within 0.005mm and its repeatability at picking up an edge or coming down against the table or workpiece was again within 0.005mm
    Hood
  2. #22
    Well, if you strike it with the built-in hammer mechanism it's thousands of volts (enough for a spark). Very little energy involved so clamping would be easy. I would think of it as an insensitive contact microphone.
    Mariss
  3. #23
    May 2003
    340
    One thought is that unlike a normal probe once you have stopped moving the voltage will disappear so you won't know you are still in contact, in most cases this doesn't matter I guess.
    The thing I like about the vibration method is that there is a chance it will work for very gentle contact on soft materials, if you could detect the clipping of the sinewave you would know you had come into contact with something. I saw a picture of a probe digitizing some cloth and they said it was peizoelectric so I guessed this is how they do it but I don't know.
    Graham
  4. #24
    Oct 2003
    175
    it doesn't take much of a tap either my electronic drums are using piezo for pick up all i have to do is tap the head with my finger and its enough to get the data to the puter the setup is just a piece a foam the piezo sits in the head stretches over the top of it
  5. #25
    May 2003
    340
  6. #26
    Exactly! You know when you are moving, the pezio device sends a signal, you stop moving and log the coordinates when you get the contact signal. It tails off afterwards alright but you still get a sharp rising edge at the instant of contact. That's what you are after.
    Mariss
  7. #27
    Jun 2003
    2103
    Mariss would this be any safer on the probe itself than one of the units that have been discussed here? I suppose I'm asking if the axis would continue to move slightly after receiving the signal or would this still be software related?
    Mike
    No greater love can a man have than this, that he give his life for a friend.
  8. #28
    I always like to simply. I saw the break-away drawing with the 4 balls and everything for a contact probe. I thought what an elegant but complex solutiuon. You jostle the balls, they break contact with a circuit. It does what it's supposed to do.
    Meanwhile I'm getting hung up with the "complex" part. Shouldn't it be easier where something gives an electronic "clang" when contact is made? Something with no moving parts at all? Like a toothpick in your ear touching your eardrum? Your'e OK until the faintest pressure touches the end of the toothpick. Lateral or on-axis, it doen't matter: you'll scream.
    Same thing here but very simple mechanically. Just a probe rod afixed to a pezio-electric crystal. Touch it slightly and it screams "contact!".
    Sorry for the gruesome analogy but it works.
    Mariss
  9. #29
    Oct 2003
    175
    just did some playing around with a buzzer i had from ratshack i noticed i get lower readings if i tap like the center was under 1 volt then if i have it push and bend the crystal bending was sending anywhere 12 to 15 volt
  10. #30
    Mar 2004
    1147
    uF... uM.,... i mean the tiny unit of measurement...
    Oh Mariss.
    That is so romantic! Perfect... You are, of course, describing the subtle sliding back-n-forth of a piezo-electric elements intermeshed current producing chrystalene structure..
    I havent spent much time with digital edge finders and 3d probes, but i have played drums for years. Electronic drums, especially those from before 1998 are based on simple piezo transducers and op-amp based amplification circuitry.
    If the 10uM deflection for a 4.5v pulse is a real rating, a simple probe based on a pizeo element seems very interesting, yeah.. No moving parts is a bit of a oversight, considering some sort of actuator must still impact the pizeo disc...
    Why dont you do some experiments.. It could be fun...
    Everyone likes new products. Especially if they are appropriately engineered, and priced for the man on the street.
    Robert
  11. #31
    May 2003
    340
    Quote Originally Posted by Mariss Freimanis
    Mariss
    Fine for bed of nails but not so good for adaptive feedplane when you need to know when the probe has left the surface.
    You need some give in the system for axis deceleration I don't suppose that would be too hard to do but it needs to give in all directions.
    Jostle the balls? There clamped!
    Graham
  12. #32
    Apr 2006
    101
    Mariss and all,
    Just use one of the piezo disks that have 3 terminals. You conect it to a single npn transistor and a couple of resistors and you have a ceramic resonator-oscillator.
    Glue the probe to it, tweak in the gain to get it to run at some frequency.
    Monitor the input current or the oscillator (ac) output voltage. When the probe is touched (any axis), the gain is reduced, the oscillator stops and you detect the current draw change or the AC output.
    I'd use a light weight probe rod and a rigid glue to get good coupling to the ball. The piezo disk mount could be the part that had the flexture that prevents destruction in the event of a crash or over-deflection.
    Where do I get the ruby ball?
    Barry
  13. #33
    Barry,
    Why does it have to be ruby?
    -Brady
  14. #34
    Apr 2006
    101
    Whats the ruby magic? - anybody ?
    Dunno - maybe the tempco. Seems like they are always ruby on CMMs. Maybe it has something to do with Kansas.
  15. #35
    Dec 2004
    524
    Use Ruby because...
    Ruby is hard (almost as hard as diamond) and cheap.
    Get Replacement Styli and Accessories for Renishaw CMM Probes from www.mcmaster.com -- $35 for a 5mm ball end probe.
    Quoting from the web page.
    (E-J) Styli— Have Grade 10 ruby balls with a sphericity tolerance of ±.000025" and a diameter tolerance of ±.0001
    I consider that pretty reasonable.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
Page 2 of 2 12
