587,999 active members*
2,134 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Oct 2005
    41
    Importing from Rhino to Mach
    I'm a total newbie, so be gentle.
    I'm just trying to do some practice runs in Mach with a DynaCNC table, when I import the attatched dxf object into Mach I get a very strange broken up object. Any hints as to what I'm doing wrong?
    Thanks in advance!! :cheers:
    Attached Files Attached Files
    35538
    2D .dxf's only. Export the profile only, not the whole 3D model.
    Oct 2005
    41
    Hey, thanks ger21.
    I've tried every combination for saving the file in Rhino as the profile only and nothing seems to give me a clean g code in mach 3. Any idea how I do that in Rhino 3?
    Once again thanks in advance! :cheers:
    Quote Originally Posted by ger21
    35538
    You need a simple 2D outline of the part. If you can't extract that from within Rhino, can you redraw one?
    Jun 2003
    2103
    Try this. I used make2d in rhino to get you a 2d dxf. 2d is all Mach will see.
    If you are wanting to carve the 3d body download the trial version of Madcam and give it a try. Meshcam can also carve it but it doesn't, or the last time I tried it, did not do vertical sides too well. Madcam has both 3d and 3d capabilities.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Oct 2005
    41
    Hey guys, thanks, I'll give it a shot.
    So am I to understand that I cannot use mach3 to do a guitar neck or an arch top because it is only 2d?
    35538
    You can use Mach3 to control the machine for 3D parts, but you'll need something else to create the g-code. You might want to look at www.meshcam.com
    Oct 2005
    41
    Thanks for all your help, I'm too much of a newbie to have known that Mach3 cannot generate 3d g code, just another example of poor service and misinformation brought to you by DynaCNC, but I'll save that story for another time. (chair)
    Oct 2004
    44
    Surprised
    I am really surprised that someone at DynaCNC told you that Mach3 Imported a 3D file. I have had conversatins with them about 3D files and they told me to go for the BobART plug-in. They told me that Mach3 did not import 3D files. I think you mis-understood the direction from DynaCNC.
    Sid
    Jun 2003
    2103
    Quote Originally Posted by gregrnel
    To reinforce what Gerry said.....yes mach can do 3d. I machine 3d all the time, and I use Rhino for the modeling and Madcam for the cam. The guitar you posted can actually be done quite easily in 2d rather than 3d. You will need all the pockets modeled but other than that you just need to get comfortable with Mach.
    I in an "extended" process of building a bass for my brother and the only 3d I will do on it is the neck. Everything else will be done with 2d.
    Mike
    ps in the musical instruments forum check out the "Lets build a Strat" thread. You might find it interesting.
    Nov 2005
    938
    MeshCAM will work nicely for you. for something slightly more expensive (and probably a lot more versitile) a lot of the guitar makers out here use MadCAM which is a pluggin that integrates directly into Rhino. There is also (on the ridiculously expensive end) RhinoCAM (the one I use) which is also a plugin and also integrates right into Rhino3D. RhinoCAM has a few free viseos to show you how it works.
    There is also another thread here called "let's make a strat" or something like that (just do a search for it). The g-code for the neck is there ready for download.
    Jul 2006
    25
    termite is rite i am journeymen patternmaker powermill , visualmill etc. rhino and mad cam can do anything dont make the same mistake as i did and buy rams gold for 1100.00 and its a joke i could not believe sales pitch, i cant give it away , tryed to sell for 400.00 and i still have it.only good for 2-1/2 d
    Sep 2006
    49
    Deskproto
    How about Deskproto and Rhino? What do you think about this?
    Apr 2007
    1955
    Hi, just reviving a question in an older thread.
    I am building up a DIY CNC router which will be run from Mach III. I do not have ANY CAD programs or experience, and am not ready to take this part on right now. I do have experience with T square based drawings on paper.
    I am also new to G code and trying to learn, but still - more or less just reading. Wow - sounds pretty lame when I spell it all out.
    Anyway, a guy I know would like to take his 3D Rhino (cad ) drawings (true 3D shapes, not 2.5) and have me cut a few parts out. I told him that he should buy a copy of Mach III as well, import the CAD file to Mach III, and send the resulting G code to me to run on my cnc router. I assumed I can provide a copy of my tool configuration information to him, and his exported G code would work on my router.
    Now that I am reading a bit more about it, I am thinking that this advice is not sufficient - perhaps wrong. After searching through the topics here and the mach support site, it seems that the steps are really more like:
    a) Draw in Rhino CAD
    b) Convert from CAD to CAM using Rhino CAM or similar
    c) Post processor - no idea what that is ?
    d) Have him import into Mach III at his site
    e) Email the file to me for running
    f) Run on my machine using Mach III
    Is this right ?
    It seems like perhaps Meshcam is easier ? Can meshcam do both the CAD and CAM conversion ? http://www.grzsoftware.com/
    If I am properly following the discussion, Mach III can deal with generating a tool path for 2.5 D objects directly from a DXF files, but not generate a true 3 D tool path from a 3 D CAD file.
    The parts are not that complex, but it is possible / likely that the parts will need to be flipped over for cutting from both sides.
    It is also likely that at least sometimes, the parts (foam) will need to be cut in sort of slices and assembled to achieve the desired thickness.
    I tried searching and reading about this topic, but I am still unsure of exactly how to go from drawing to part.
    Thanks for helping direct me.
    HarryN
    Jun 2003
    2103
    Quote Originally Posted by harryn View Post
    b) Convert from CAD to CAM using Rhino CAM or similar Yes and that similar would be Madcam! I am the US reseller for Madcam so you know what I'm going to suggest!
    c) Post processor - no idea what that is ?Built into Madcam and probably most other cam packages
    d) Have him import into Mach III at his site No need if you are going to run the part
    e) Email the file to me for running email the gcode created by the cam package
    f) Run on my machine using Mach III Bingo!
    Is this right ? yes
    It seems like perhaps Meshcam is easier ? Can meshcam do both the CAD and CAM conversion ? http://www.grzsoftware.com/ meshcam doesn't do the model
    If I am properly following the discussion, Mach III can deal with generating a tool path for 2.5 D objects directly from a DXF files, but not generate a true 3 D tool path from a 3 D CAD file. Mach3 only uses gcode that you supply and uses those gcodes to actually move the machine by putting signals to the motor drivers ......another discussion
    HarryN
    Harry can you supply one of the parts? If so I or someone else can do you a gcode from it so you can see the process.
    Mike
    35538
    A) create the 3D model in Rhino, and export into a format that the CAM program can accept.
    B)The CAM program will create the g-code from the model.
    C) the post processor is part of the CAM program. It's purpose is to tailor the g-code to a particular controller
    D) Load the file into mach3 and start cutting.
    Apr 2007
    1955
    Hi
    Thank you Turmite and Ger21 for the info.
    Turmite
    - It is fine to recommend what you sell/ belive in
    - If I correctly understand it, Madcan is intended for use by a Rhino CAD user and becomes more of less an integrated part of the Rhino user experience ?
    - That makes it ideal for a Rhino user, but if you do not own Rhino, perhaps not as useful ?
    - I will look at the demo versions of Rhino and Madcam, but right now, I don't own ANY CAD or CAM software.
    I appreciate your offer to transfer one of the part drawings from 3 D CAD to G code. At this point, I cannot take you up on that as I don't have the part drawing, but it is more or less similar to a large RC airplane wing in shape. It is too thick to cut from one piece, and requires flipping of both parts for machining, then assembly of the partially overlapping "slabs" to make it all work.
    That is what makes it very useful to if the software can help deal with parts which must be machined in 3 D from both sides, and assembled from these 3 D shaped "slices" parts.
    At least I now have a better understanding of the flow. It looks like I am going to have to own some kind of CAM software no matter what.
    Jun 2003
    2103
    Harry here is a shot of a project I did in slices and then glued them together. It sounds like something like you might be doing.
    Mike
    Apr 2007
    1955
    Thanks - that is a good indicator of what I need.
    35538
    Both MeshCAM and Cut3D can do slicing of your model. They can also do both sides of your model. However, I'm not sure if either one can do both slicing, and both sides combined. Although it is possible to do your own slicing in your CAD program and then export the separate pieces for 2 sided machining.
    www.meshcam.com
    www.vectric.com
Page 1 of 2 12
