588,136 active members*
6,270 visitors online*
Thread: Help!
Results 1 to 6 of 6
    Dec 2014
    5
    Help!
    Noobie question
    I'm trying to create a .086 width groove with a .038 radius and a .010 flat in the middle but can't seem to achieve it with a .062 full radius tool on OSP-U10L Okuma. Any ideas on how I can achieve this?
    Thank you.
    Aug 2011
    2517
    Re: Help!
    I assume you mean programming it using IGF? Or do you mean program it with G-Code?
    Are you getting an error code or message or the machine just won't do it with no messages?
    Dec 2014
    5
    Re: Help!
    Sorry for the late reply. Yes it's on One Touch IGF and the error code it 2063 nose-r comp. Straight line to arch 1.
    Aug 2011
    2517
    Re: Help!
    normally what I do to get around that problem is define the tool as the same width but with a smaller radius. so define tool as 0.062" wide with 0.030" radius. it will have a 0.002" flat in the middle.
    try that and let us know if it works for you.
    Dec 2014
    5
    Re: Help!
    I'll give it a whirl and see what happens. I'll keep you posted.
    Thanks a lot fordav11.
    Dec 2014
    5
    Re: Help!
    It worked out! Just has to tweak the radius a little but it put me in the right direction.
    Thanks so much fordav11.
