603,781 active members*
3,767 visitors online*
Results 1 to 9 of 9
    Jul 2003
    92
    Laser spindle alignment?
    Hello. Someone mentioned in response to one of my previous posts that if I didn't use home switches to provide a reference for starting my cutting, that I could use the software and "jog" the spindle to where I wanted to start. Sort of like placing a drill bit where you want it to start drilling. After locating the spindle, I zero the software and let it go.
    This strikes me as quite a bit easier and perhaps even more reliable that using home switches.
    I wonder if anyone has developed some sort of laser guide I could place on the machine that would project a dot I could use for alignment on the workpiece? I sorta envision a small laser pointer adapted to fit on the end of the router bit.
    Also, if I do want to use home and limit switches, what kind to people suggest for the most accurate repeatability?
    Thanks,
    Phil
    Apr 2003
    416
    Phil,
    I like your idea about a laser guide for zeroing the machine. If you had a light sensor that picked up the laser, you could set zero when the pickup registered. I don't know how easy it would be to keep in alignment.
    Check out the picture of how I am doing it thread "my cnc hobby" (page 2 - 4th post down).
    Bill.
    4826
    I read an article just recently on some site about just such a device used to set up serrated chuck jaws to the proper diameter. It was on that cnc instruction site
    http://www.cncci.com
    Look under products/helpful tools/laser jaw setter
    Although "laser jaw setter" is what it is called, there is nothing stopping you from using it for other purposes. Just don't tell them when you order
    Aug 2006
    157
    laser pointer
    maybe i am simplifing it too much but couldnt you just mount a small handheld laser pointer on the x axis , it might take a litlle aligning at first but once it set should work i ahve been thinking about it for a plasma cutter to just make zeroing on work easier
    tim
    Jul 2004
    374
    Since you're using your eyes to "eyeball" the laser spot, I think you're leaving a lot of accuracy and repeatability on the table. If you were able to use a type of system similar to what is used for laser "surveying" a machine tool, that would be optimal, but probably very expensive.
    If you're just trying to find something like a physical point on a part, (without regards to a physical edge) a sharp point wiggler spinning in the spindle can get real close.
    If you have edges to work with, the gage ring and indicator method is the most accurate/repeatable method that I can imagine.
    I know these aren't as elegant as a laser locating system...I'm curious to see what you come up with!
    Justin
    Re: Laser spindle alignment?
    I developed a Laser Jaw Setter specifically used for setting jaws on the chuck accurately.
    Oct 2005
    58
    One way to get a point on the table would be to mount a laser in the router, then jog to the point needed. Or better yet to mount the laser pointer to the Z axis a known offset from the center of the router bit so it is always mounted. The URL for one used by machinists is below, they are reasonable (about $125 for battery powered and $150 for 120V).
    Welcome to Laser Center/Edge Finder
    May 2005
    3920
    Laser spots that you can actually see are pretty big thus not really suitable for zeroing out a machine. This especially if you need high accuracy.
    Seriously I suspect you would be better off with a traditional machinist edge finder and use that to locate off a fixed datum. You would need to be able to run your spindle at a reasonably slow speed to use the edge finder.
    Quote Originally Posted by cgallery View Post
    You can certainly do that though it is a real pain compared to a machine that homes reliably. Homing switches and routines make life far easier.
    Not a chance. Given a controller that can run proper homing cycles you can re home a machine on all three axis in less than a minute if the arises are relatively close to the home switches. Doing so you can get repeatability to around a thousands of an inch and even higher if using servos with encoder feedback.
    How about in a collet? I have seen such alignment tools so your idea has already been made into a product.
    There are probably a 100,000 different limit switches and position detectors out there. Usage is a big factor in selection. For example do you need oil tight? High precision costs more generally.
    Thanks,
    Phil
    Id suggest shopping around a bit with the online catalogs to get an idea of what can be had out there. You can easily spend $3 or $300 and not get the right switch. It isn't like you have to rush out and buy homing and axis limit switches right away as you can do your homing manually.
    Feb 2007
    711
    This is an 8 year old thread.
  1. Basic Laser Alignment
    By jd75 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-28-2014, 11:12 AM
  2. New DIY Laser - some tips on alignment
    By shobley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-02-2012, 11:36 PM
  3. Laser alignment off badly, possible causes?
    By InfernusDoleo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-02-2012, 02:18 AM
  4. newbie needs help with laser alignment
    By dominic gailgan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-10-2012, 09:02 PM
  5. Laser Beam alignment
    By graver1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2011, 05:48 AM
