587,409 active members*
3,268 visitors online*
Page 1 of 3 123
Results 1 to 20 of 43
    Jun 2009
    138
    Wire rope driving mechanism
    No ball/lead screw
    No rack and pinion
    No chain and sprocket
    No driving belt
    No linear guide
    stand alone table
    5 axis
    Zero backlash
    Very smooth movement
    The cheapest cost
    It is my own upgraded technique using threaded steel pulleys and wire rope .. let us start talking by photos.
    ___________
    The X-axis driving mechanism
    Just one fixed stepper motor for the gantry
    Attached Thumbnails Attached Thumbnails IMG_5125.JPG   IMG_5126.JPG   IMG_5133.JPG   IMG_5138.JPG
    Jun 2009
    138
    Re: Wire rope driving mechanism
    The Y-axis driving mechanism.
    Motor is moving with Y-car not with Z-car.
    Attached Thumbnails Attached Thumbnails IMG_5122.JPG   IMG_5123.jpg   IMG_5135.JPG   SUNP0102.JPG
    Jun 2009
    138
    Z-car using the same technique.
    Attached Thumbnails Attached Thumbnails SUNP0100.JPG   SUNP0099.JPG   SUNP0105.JPG
    Jun 2009
    138
    Stand alone table & 30.0 mm bar as a track.
    Attached Thumbnails Attached Thumbnails PHOT0009.JPG   IMG_5142.JPG   IMG_5143.jpg
    Jun 2009
    138
    After primer and hammer finish plating
    Jun 2009
    138
    Control unit chassis made by my diy cnc plasma m/c includes the following:
    1- power supply, contactors, relays and rosets.
    2- drivers & interface BOB and screened cables.
    3- PC, screen
    4- inverter
    5- oem control switches.
    Jun 2009
    138
    Rotary axis (across X axis) under progress.
    Able to rotate work pieces up to 350.0 mm ( 13.5") diameter.
    Could be rotated around the Y axis to give the 5th manual axis facility.
    Nov 2014
    9
    I really enjoy looking at threads such as yours which include ingenious approaches to DIY CNC. In this case, steel wire is strong in tension, so I can see why you chose it. I will be interested in seeing what challenges it introduces and how you deal with them. One thing that I see is in the first post the cable is winding around a rod, and I imagine that as the cable winds around the rod, the angle of the cable will change, so this will shift the alignment of the cable and possibly cause issues (just guessing). I am curious if this is a factor and how you deal with it.
    Thank you for sharing your photos. I wish you continued success in your project.
    I really like the color, by the way.
    Jun 2009
    138
    Quote Originally Posted by BassBone View Post
    Thanks for your comment.
    The cable is not winded around an ordinary rod but around a threaded rod and inserted inside its teeth , this threaded rod moves axially during its rotary movement via a fixed nut forward and reverse to compensate the axial displacement of the wire.
    So the wire will be maintained straight without any angle owing to the axial movement of the threaded rod.
    I think that the clip of the machine movement that I will post within a few days will clarify every thing.
    But you can have a look to my DIY plasma in this thread, it is also by using wire rope but a different design.
    http://www.cnczone.com/forums/plasma...cnc-forum.html
    Nov 2014
    9
    That's a very clever way to accommodate the wire winding around the rod. Thanks again for explaining this and for providing the illustration.
    Jan 2007
    1795
    around 95 we built a painting machine with rope.. there were no issue the repositioning, because it painted in one pass..
    I never tought it could drive real cutting machine..
    very cool anyway.. folks could learn creativity from you..
    Jun 2009
    138
    This is a simple illustration showing the difference between the wire winded around an ordinary rod and that's winded around a threaded rod.
    The pitch of the rod thread is about 1.2 times the wire diameter to allow an accepted clearance between the wire winding , this way achieves the following:
    1-double friction between the wire surface and the rod which prevents slipping (two winds are more than enough to ensure a tight coupling)
    2- prevents wire winding from overlapping or any chaos.
    3- Control and organise the relationship between the radial and axial movement of the wire depending on the thread pitch.
    Aug 2014
    60
    Quote Originally Posted by Islam View Post
    I like it great idea
    Nov 2012
    25
    I have done this with Kevlar fishing Line. The issue you will have is that as it wind the wire position move. My test rig which used a 1/4inch 20tpi threaded rod the wire move about 1 inch side to side per every 13 inch of lateral move ment. this Side to side movement affect the geometry. unless you did like i did which is to put the drive at the gantry. and put the attachement of the cable to either end of the table and offset them accordingly.
    My Machine used fishing lines, which can only handle 60lb per line with 250oz inch Motor the line will break befor the machine lost step. This is more then likely caused partially by the tension on the line. Also at about 10inch per sec Acceleration the line will break. My machine has a 50lb gantry and I used 4 lines when i did this test.
    The machine with fishing was capable if runing a 1/4 router bit with 1/4 inch deep cut at 45 inch per min on ply wood. as long as the accel was low. And Rapid is in the range of 250 inch per min.
    But after all this I thought it was a perfect cheap system for somthing like a 3D printer.
    Attachment 264228
    Jun 2009
    138
    Quote Originally Posted by Coydog View Post
    Attachment 264228
    Finally, I have finished my machine and tested it, the machine is running very smooth and this issue is not existed owing to the axial movement of the threaded pulley as I have mentioned before which compensates this offset.
    I will attach the clip of my machine movement.
    Jun 2009
    138
    My first cut using the rotary axis besides the 3 axes.
    Jun 2009
    138
    Some photos of the machine after finishing.
    Jun 2009
    138
    Auto tool zero & Y axis movement.
    https://www.youtube.com/watch?v=osf9...ature=youtu.be
    Jun 2009
    138
    An adjustable derlin brake has been fixed along the axis of the rotary to eliminate any vibrations due to the backlash of the gearbox during the cut.
    Jun 2009
    138
    Part of the table has been designed to fix the small work pieces up to (15" x 30") using sliding bars and also used for square columns.
    Attached Thumbnails Attached Thumbnails IMG_5446.jpg   IMG_5474.jpg   IMG_5480.jpg
Page 1 of 3 123
  1. CNC Table with pulleys and wire rope
    By celephicus in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-02-2015, 11:31 AM
  2. Wire Rope instead of belts / ballscrews
    By appicnc in forum DIY CNC Router Table Machines
    Last Post: 07-24-2014, 02:06 AM
  3. Possibility of driving 8 wire stepper motor with two TB6560 drivers ?
    By rajithilanga in forum Stepper Motors / Drives
    Last Post: 05-12-2014, 05:56 PM
  4. Where to buy wire rope by the meter? (Australia)
    By Splint in forum Australia, New Zealand Club House
    Last Post: 09-20-2007, 11:22 PM
  5. Problems with three wheel driving mechanism
    By shaiqbashir in forum Servo Motors / Drives
    Last Post: 01-06-2007, 06:42 PM
