Ah hoi hoi!
This will be my second build, my first being a scratch built wooden chain drive machine that started out as a jgro 4 years ago as a high school project. I originally built the jgro to the book, however after pulling much of my hair out and getting less then satisfying results, the machine got put on the backburner for a few years and became another horizontal surface junk collector in the shop, go figure! fast forward to the beginning of last year, I designed a machine that would incorporate the jgro base with v bearing and a chain drive system. the machine has been up and running now for the previous year, and has produced some very nice projects, as well as some very frustrating failures.
A wooden machine build and chain drive maintenance and constant adjustment has been a real learning experience, but it came time to get serious about some projects, a new machine was inevitable.
I started purchasing parts for the new machine in mid January, and by next week should have everything required for all the finishing touches.
current parts list/ plan
2x4 FineLine Automation router with cable chain kit
Nema 34 electronics kit from CNCRP
gecko driver motherboard from CNCRP
smooth steeper from CNCRP
proximity limit switch kit from CNCRP
220v vacuum pump for a bleeder board hold down from Lighthouse ENT
19" touchscreen
2.2kw spindle from Chai
double 120mm radiator and parts for a closed coolant system
Igus cable flex wire for the spindle
too many odds and ends to list
I will have a full parts / price list at the end of the build if anyone is interested
