Good decision...
The chip is quite hot at currents above 2.5Amp and some other components also heat up depending on the supply voltage.
Best solution is a small breeze from a fan to keep everything cool, same applies to TB6600.
Cables can be several meters long if a decent gauge is used, I normally use shielded 0.75mm².
