588,229 active members*
4,469 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Hi everyone need help.. for bridgeport TC2 with TNC370 Control
Results 1 to 2 of 2
    Oct 2014
    7
    Hi everyone i really need help.... i'll be very grateful if someone does..
    just bought a 1999bridgeport tc2 w/TNC370, .
    can't find the machine operators manual, got the rest from heidenhain
    already familliar with the tnc355...i have a hermle uwf900 w/tnc355 got it with the ext. trans. cable,
    i also need the following...
    -post proccessor tnc370 for edgecam,using the 355 but have to edit the prog everytime (open to any suggestions for 2-3D machining....)
    -pins assignment for the ext data transfer,cable (again i'm open to any sugg.....)
    -machine jolts when using blockwise transfer machining (when using cable of a tnc 355), which parameter can smooth things out tried 1390,...
    -looking for heidenhain handwheel encoder rod450 H 5000
    -and having problems with the tool setter calibration..
    thanks ,
    Feb 2013
    23
    Re: Hi everyone need help.. for bridgeport TC2 with TNC370 Control
    Hello bcslc,
    I have the same machine, probably late with the reply, but here goes:
    Service manual: https://www.dropbox.com/s/lv9ww7q4ar...anual.pdf?dl=0
    Operators manual: https://www.dropbox.com/s/lv9ww7q4ar...anual.pdf?dl=0
    Data cable pinout: https://www.dropbox.com/s/9hc938orly...dhpin.PNG?dl=0
    for blockwise transfer use TNCserver (bundled with TNCremo) and make sure you have the same baud rates and using FE transfer protocol.
    I am in need of the machine parameter list which can be exported with TNCserver running on PC
    Hope this helps someone
