588,487 active members*
5,475 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Containers for chip/coolant recovery
Results 1 to 7 of 7
    Sep 2004
    23
    I am looking for suggestions on what to use as chip/coolant recovery bins to use under our Haas chip conveyors.
    We currently use 2 plastic bins. We drill holes in the top one to allow the collant to drain into the second one. We buy these at local reno store but they are cheap and often break.
    I am hoping to get a more commercial and durable product.
    Any ideas ?
    What do you guys use ?
    Thanks,
    Pharkas
    May 2004
    4519
    Several options. The main suppliers should have metal hoppers, some are self dumping, with and without casters. Uline has some heavy plastic hoppers on wheels I think. If you are worried about breakage, don't be cheap. If you are trying to recover 1 gallon or less of coolant from a cubic yard of chips, you might want to rethink your value system. Cycle your chip conveyor when coolant is off if possible.
    Apr 2006
    3206
    For oil recovery for screw machine chips we'd drill 4 holes in the side of a 55gal drum and a lid. When the barrel was full, put the lid on, wire it, and turn the barrel on its side on one of those dollies that lets you draw fluids from a barrel via a spigot.
    Put a 5gal bucket under the lip and let it drain for a few days. (at $5/gal for cutting oil back then, it was well worth it). I could easily get 5gal or more from a barrel of brass chips.
    Too bad you can't have the chips flow up through the coolant after it's been sitting, and act like a skimmer for the tramp oil....
    Global has lots of plastic containers for various uses. Their catalog could give some ideas for variations on your theme... which seems like a good one.
    Apr 2006
    3206
    Quote Originally Posted by txcncman View Post
    Good point about recovery efficiency. I was thinking plastic because they're relatively inexpensive compared to steel... and if you don't beat 'em up they'll last for a long time (if you don't buy the cheap ones).
    Sep 2004
    23
    A bit more info....
    My main concern is keeping the floor clean. Recycled oil qty does not really matter.
    We use small plastic containers on each cnc, which are then dumped in big metal containers which are then sent for recycling. If the chips are
    Not drained, a coolant pond forms under these metal bins.
    Pharkas
    Jul 2005
    12177
    Quote Originally Posted by Pharkas View Post
    A bit more info.........a coolant pond forms under these metal bins. Pharkas
    We found he easiest way around this was to put the big bin on blocks with small tubs under the places where the coolant drained out.
    Jan 2015
    Re: Containers for chip/coolant recovery
    ha guys cheapest way to keep coolant clean use oil skimmer oil skimmer, tramp oil skimmer, cnc skimmer
  1. New Table chip/coolant guard
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 01-22-2014, 09:48 PM
  2. A simple chip and coolant deflector
    By SteveKoerner in forum Tormach Personal CNC Mill
    Last Post: 12-20-2013, 11:50 PM
  3. Chip/Coolant Containment
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 11-18-2012, 03:54 AM
  4. VM-2 coolant/chip problem
    By extanker59 in forum Haas Mills
    Last Post: 11-08-2011, 03:40 PM
  5. coolant recovery vacuum?
    By cncatj in forum Uncategorised MetalWorking Machines
    Last Post: 03-04-2007, 01:44 AM
