587,999 active members*
5,202 visitors online*
Results 1 to 9 of 9
    Dec 2011
    316
    UHMW Speeds & Feeds
    First time using UHMW. Needless to say less than stellar results.
    Either it's not very machine able or my feeds & speed & feeds are way off.
    Using a 1/2" 2 flute carbide FEM.
    Suggestions appreciated.
    John
    Feb 2006
    7063
    Re: UHMW Speeds & Feeds
    John,
    Spindle at max RPM, LOTs of coolant, and haul a$$. I typically cut at anywhere between 50-100 IPM, depending on depth. For a clean cut, get straight-flute endmills, or just use carbide router bits. Also, leave enough for a generous finish cut (0.025-0.050") as you can't take off just a little very effectively. If going deep, do a final spring pass for best dimension.
    Regards,
    Ray L.
    Dec 2011
    316
    Ray
    Appreciate the info. Will try again tomorrow.
    John
    Oct 2012
    342
    I use the same endmills I use for aluminum, 3 flute carbide. Make sure your end mill is razor sharp, UHMW doesn't like a dull cutter. Like Ray said max RPM, I don't have flood coolant so I start 20-40 IMP and an air blast.
    Dec 2011
    316
    Gents
    A quick update. Tried a new HSS coated cutter (very sharp), 50 IPM & flood coolant. HUGE difference.
    Only remaining issues:
    1. Finish on chamfer sucks. (6000 rpm, 50 IPM). See attached photo.
    2. Defining chamfer in Bob Cad not terribly intuitive.
    Thanks for the advice
    John
    Feb 2006
    7063
    John,
    That surface finish is still pretty awful - should be MUCH better. You will do a lot better with a straight-flute tool.
    Regards,
    Ray L.
    Dec 2011
    316
    Ray
    Will check it out
    John
    Jun 2004
    6618
    I use Delrin in my products. I like it better tan nylon and UHMW. It cuts really well on the lathe.
    Lee
    Feb 2006
    7063
    Delrin is great for some things, but it's a very different material from UHMW, and UHMW is a fraction of the cost. UHMW is really great stuff for many applications. I use it both as part of the structure, and for bearing surfaces, in my PDBs and ATC. It's softer, but also "slicker" than Delrin, making for very smooth, quiet operation. Delrin certainly machines better, and you can achieve a better surface with tighter tolerance, but UHMW also machines well using the right tools. I use Delrin for the "lift" leadscrew on the ATC, where UHMW would be too soft (though the production parts will be Turcite, which is considerably lower friction than Delrin).
    Regards,
    Ray L.
  1. Feeds and Speeds on UHMW Sheet???
    By ClickDraw in forum PhotoVCarve and VCarve Pro
    Last Post: 01-05-2015, 07:57 PM
  2. speeds and feeds
    By dek in forum RFQ Feedback
    Last Post: 03-16-2010, 05:23 PM
  3. Speeds and Feeds
    By fenix in forum Uncategorised CAM Discussion
    Last Post: 01-22-2010, 07:07 PM
  4. Speeds and feeds (I know, I know)
    By mrcodewiz in forum Benchtop Machines
    Last Post: 10-18-2008, 09:00 AM
  5. feeds and speeds
    By porkchop21 in forum Bridgeport / Hardinge Mills
    Last Post: 08-31-2007, 01:52 AM
