588,201 active members*
5,109 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > I need some help sourcing some equipment
Results 1 to 2 of 2
    eitanwaks Guest
    I need some help finding two linear blocks. The ones I have on my rail right now are THK HSR 35. The problem is that I only have one for rail and after doing calculations for my design I'm afraid that they might not be able to hold up under severe conditions. The problem is not the blocks rather something attached to them that will generate too much moment. If I could find two more blocks I could remedy the problem.
    I've tried eBay but haven't seen any for weeks. Does anyone have any suggestions on where I should look? Like everyone here I would like to purchase them as cheap as possible.
    Thanks,
    Eitan Waks
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
