587,737 active members*
3,157 visitors online*
Page 10 of 11 891011
Results 181 to 200 of 201
  1. #181
    Jan 2013
    306
    Re: Steve's 2x2 CNC Router
    It is a carbide end mill.
    Here is the part number but I think I got it on eBay.
    1/4" Square End Mill Standard Length HTC 120-2250 2FL GP 30
    What problems are you having?
    Steve
  2. #182
    A lot of chattering, broken bits, etc. I believe a combination of an aggressive DOC and speed.
  3. #183
    Jan 2013
    306
    Could be a bad collet or bad spindle.
    Are you using a router or spindle?
    Steve
  4. #184
    I was using a Bosch router (non variable speed). The last cuts where to create the mounting plates for my spindle which I haven't tried on aluminum yet.
    In other words... Cutting too deep, moving too fast and spinning way too fast!
  5. #185
    Jan 2013
    306
    With a router need really shallow cuts. I ran a router on my machine for awhile and cutting aluminum was tough. The bearings are not all that great in most routers.
    Steve
  6. #186
    Agree! I'm using a 4.4hp spindle now and I'm sure it would be much better! Double bearings at the nose helps quite a bit.
  7. #187
    35538
    Try a single flute "O" flute bit. I've gotten good results with an Onsrud "O" flute, even with a worn out PC690 and my flexible machine. Be sure to climb cut.
  8. #188
    Steve, I feel like I'm high jacking your thread...Gerry, are you using coolant?
  9. #189
    Apr 2009
    5516
    Quote Originally Posted by bobmagnuson View Post
    If you do the math you should be able to get good cuts even with a router. The feedrate = no. flutes x rpm x chipload. For a 1/4" bit I use a chipload of .0025-.003". With my SuperPID on the router setto 12krpm that equals 32-36ipm per flute. For my router I pocket at 1/2D for pocketing and 1/4D for slotting. You should use some sort of lubricant to keep the aluminum from galling. The jey is using the highest speed you can with the largest chpload your machine can handle, so the heat is on the chips not the work. I can hold my endmill after a job.
    Also, cast and ground aluminum plat (mic6) routs easier since the chips break up nicely. If your chips look like powder you're just wearing out your endmills. If you have to route at high rpm I've been suggesing single edge spiral o flute bits for years, they work great at high rpm. Then you can switch to a 2 or 3 flute for the finish pass if needed.
  10. #190
    35538
    No, I was cutting cast plate, and cutting dry.
  11. #191
    Jan 2013
    306
    I am cutting 6061 T-651 right now. Cutting with a kool mist mainly to keep chips cleared but adding just a small amount of coolant.
    Cutting deep slots need to keep chips out to avoid recutting chips.
    Steve
  12. #192
    Quote Originally Posted by Spk64 View Post
    ... adding just a small amount of coolant.
    What's a small amount?
  13. #193
    Jan 2013
    306
    Can barely see the mist.
    Steve
  14. #194
    Thanks. What type of mist system are you using?
  15. #195
    Jan 2013
    306
    It is Trico mist system. Not sure it is a required item. But let's it run without me babysitting.
    Steve
  16. #196
    I'll have to investigate either a mist or droplet system next time I have to cut aluminum. Sure would be less messy than spraying wd-40!
  17. #197
    Jan 2013
    306
    I have had my Trico for about 25 years Still going strong.
    Finished up 3 more groups of brackets this afternoon.
    Attachment 267116
  18. #198
    Nice! I've been reading a little about the misters, etc. Do you get any 'fog' in the shop or oily over spray?
  19. #199
    Feb 2011
    91
    try metho as a coolant.
    We used to cut miles of ally, even the soft sticky types, and it works very well. Just make sure there is plenty of ventilation or you will get a serious headache after a few hours.
  20. #200
    Jan 2013
    306
    In the 30 years of using the misters in my own shop and at a job shop we never had a fog problem. We always ran them fairly low air or low on the coolant so as to not flood the air or machine.
    When I am cutting on the router there might be a teaspoon of fluid on the parts.
    It is coolant mix so there is some residue from that.
    Steve
  1. Anybody know what happened to Steve Seebold?
    By toothandnail in forum Tormach Personal CNC Mill
    Last Post: 04-03-2013, 02:57 AM
  2. Anyone buy a Steve Simpson 4th Axis?
    By WOTDesigns in forum Benchtop Machines
    Last Post: 12-12-2012, 09:35 PM
  3. steve pen
    By steve pen in forum Milltronics
    Last Post: 11-10-2012, 03:15 PM
  4. Steve Timmons
    By TheBigJW in forum Complaints and Praise Discussions
    Last Post: 08-07-2012, 03:08 AM
  5. Steve's design for a Breakout Box
    By Steve-Tee in forum CNC Machine Related Electronics
    Last Post: 01-04-2008, 06:07 AM
