Re: Post processor missing tool number and feed rates
Hi Leo,
Which version of madCAM are you using? The problem you described was easy to replicate in older versions if your tool was not in the default tool library. When madCAM posts it refers back to the tool specifications, and if it can't find it, the feed rate and tool number would be blank. In version 5, that problem is non-existent IF you have your tools, machines and posts configured in the options.
![Click image for larger version.
ID: 268682](https://en.industryarena.com/forum/attachment.php?s=67b2318df14837ea518fa10040c90e78&attachmentid=268682&d=1423820646&thumb=1)
This is an important step to configuring madCAM for your use.
Dan
p.s. I just re-read your 2nd post. Did you save the cutter after you defined it?
