587,419 active members*
3,311 visitors online*
Results 1 to 10 of 10
    Sep 2003
    66
    Question Will These Work (Stepper Motors)
    I have a home made unipolar stepper controller using the UCN5804B. I got three matching motors off ebay for $6.00 ea. the motors are marked:
    Superior Electric / SLO-SYN
    1.25v
    3.8a
    Hold 60 oz. in.
    200 steps
    I am building my own design table with a working area of 18" x 18". Here are my questions:
    1 - Will these have enough holding (60 oz) to do the job.
    2 - Since they are rated at 1.25 volts and 3.8 amps will I still need to use high wattage resisters if I go to 12 vdc, and if I do, what would the value of the resistors (Ohms and Watts) be.
    Thanks,
    George
    (aka Hawkeye)
    2139
    3 ohms, 35 watts will get you 3.33 amps to the motors. 2.5 ohms gets you 3.92 amps to the motors. All this according to StepperCalc. www.e-zflight.com/files/stepcalc102.zip
    You can't drive these motors off the IC, you will need transistors or FETS to drive them.
    The above calcs. assume your using FETS for the outputs.
    Eric
    I wish it wouldn't crash.
    Sep 2003
    66
    Thanks Balsaman,
    Do I need to find a new driver or some new steppers?
    What About These - Good buy or not (can they be used???)
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=42920
    I was thinking that all I needed to do was maybe drop the voltage to 5 vdc (still 4 times higher than rated) and throw in some 2 ohm 10 w resisters and be flying. I am still very new to all this and appreciate any and all comments.
    Thanks,
    George
    (AKA Hawkeye)
    Sep 2003
    66
    bump
    2139
    I think that the UCN5804B is good for only 1.25 amps. You can use the board you made to drive FETS that drive your existing steppers. I will see if I can locate a schematic if you need one.
    Eric
    Sep 2003
    66
    That would be great, Thanks Balsaman.
    Did you get a chance to look at the steppers on the ebay link?
    what do ya think?
    Thanks again,
    Hawkeye
    2139
    Those steppers will work great, but are still over the current of the UCN5804B.
    Also, if you go with the first motors, go with 12 volts, not 5.
    Eric
    Sep 2003
    66
    Great, I will.
    Here is the schematic of the stepper driver I built:
    I am scouring the web trying to find the additional FET circuit I need.
    I am going to use an old computer power supply. It's 12vdc is rated at 7.5 A and the 5vdc is 21 amp. I think this should be plenty.
    Sep 2003
    66
    Balsaman,
    Is this more like what you were talking about (Driver)?
    http://www.piclist.com/techref/io/st...step/index.htm
    Thanks,
    George
    2139
    The 5 volt side of that PS wiull be plently if that's how you will drive the motors. If 12 volts it's undersize. You need to add up all the winding currents. 3.8 amps x two windings x 3 motors.
    That driver is also a little light for your motors.
    Here are some that might work: www.alltronics.com/kits3.htm
    3rd from the bottom of the page.
    Eric.
  1. Does anyone know of a controller board for synchronized stepper motors
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-04-2005, 05:06 AM
  2. Looking for controller board for synchronized stepper motors
    By Yellowbeard in forum CNC Machine Related Electronics
    Last Post: 04-02-2005, 03:50 PM
  3. Stepper Motors
    By kellogs72 in forum Stepper Motors / Drives
    Last Post: 11-30-2004, 02:27 AM
  4. Stepper motors...
    By Mikael in forum Stepper Motors / Drives
    Last Post: 09-14-2004, 10:41 PM
  5. disassembly of stepper motors
    By dhprc2 in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 01:09 AM
