588,137 active members*
5,828 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > DIY 2 X 72 Belt Grinder With CNC'd Components
Page 3 of 4 1234
Results 41 to 60 of 63
  1. #41
    May 2014
    3
    Re: DIY 2 X 72 Belt Grinder With CNC'd Components
    Awesome build it looks real close to the TW-90 all of us Knife makers drool over. I hope to find plans for one and build my own. I am to cheap to buy a machine already made.
  2. #42
    Hi Jimmy2405,
    I did a lot of research prior to building my 2 X 72 Grinder. I tried to take the best of each design and incorporate them into my grinder. The TW-90 is a really nice machine and I liked his tool rest system a lot so I used a similar system on my machine. Wilmont also make a fine 2 X 72 Grinder. I made a lot of different brackets to make the tables as adaptable as possible. I use my machine almost every day and I love it. The variable speed and my rotary platen design makes it the cats meow.
    A BIG THANK YOU to everyone that has posted pictures and video of their machines.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
  3. #43
    May 2014
    3
    Re: Rotary Indexing Platen In Aluminum
    Here is a place for those who want to build a belt sander to start. You can use the parts of this you like and adapt the rest to your liking.
    KMG Clone blueprints (Image Heavy!) - The Knife Network Forums : Knife Making Discussions
  4. #44
    Lightbulb Re: Rotary Indexing Platen In Aluminum
    Well I have been using my Ultimate Grinder for quite a while now and it for sure the most utilized tool in my shop. It replaces 3 or 4 other grinders, buffers, sanders that are presently taking up valuable floor space in my home shop.
    I finally got around to making a proper video that shows all the features of the grinder, various tool bars including one for deburring, polishing, VFD and most importantly my original design of the Rotary Platen for 2 X 72 belt grinders.
    I did a ton of research looking at all the 2" X 72" Grinders and tried to take the best from each of them to make myself what I call the ULTIMATE GRINDER.
    The reason I chose to take on this project was that I have a bunch of individual grinders, buffers, and finishing machines around my shop that are taking up valuable floor space. I thought it would nice to have "ONE MACHINE" that could perform all of the grinding, sanding, deburring, polishing operations in my home shop. i.e. the Ultimate Grinder.
    Since completion of this project I have found this to one of the most utilized tools in my shop as it does so many different things.
    The nice thing about this machine is that if you come up with another idea you can just develop another tool bar and you are in business. The possibilities are endless. Some people have even attached vacuums to them for dust collection which is another good idea.
    I have OneCNCXR5 Mill Professional software and chose it to do all my CAD/CAM work. The majority of the work on this project was designed in that software. I utilized my HAAS TM1P Vertical Machining Center to cut those parts. That way I can easily duplicate the process should I ever want another one. Some lathe work was needed and I performed that work on my Clausing 5913 manual lathe.
    Here is a link my YouTube video: 2" X 72" Ultimate Grinder 02-18-15 - YouTube
    Enjoy!
    John
  5. #45
    Dec 2007
    2134
    Just watched the video John, what a great job. I can really see that being such an incredibly useful tool in any workshop. Once I've got my more immediate stuff out of the way I'll most definitely be building one myself. I can replace three other really old bulky sanders/grinders I have with just that.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  6. #46
    Hi Ian,
    Thanks for the favorable comments. It was a ton of fun to build and even more fun to use. I love it. It basically takes care of all of my grinding, sanding, deburring, and polishing operations utilized in finishing my machined products. That is why I call it the Ultimate Grinder. Ha Ha
    John
  7. #47
    Apr 2009
    5516
    Quote Originally Posted by HelicopterJohn View Post
    Hi Ian,
    John
    Great news John, glad to see you're still at it!
  8. #48
    Hi Louie,
    Good to hear from you again. Yep, I love my Ultimate Grinder. :banana:
    I am now into Kayak Fishing. My efforts have drifted into developing products for marine applications. I have made several Steering Systems for Kayaks that utilized transom mount trolling motors like the Minn Kota. I started out with a manual foot pedal system. Then I added electric steering with manual foot pedal backup. My latest unit is controlled via an linear actuator, has backup foot pedal controls and also has the ability to remotely control the tilt and trim of the trolling motor from the seated position in the kayak. It is almost like the Ultimate Grinder as it gives FAST, SMOOTH Fishing Kayak Steering. I have several You Tube videos on this project.
    Project Overview
    https://www.youtube.com/watch?v=YhZadqCI0JI
    Tilt and Trim
    https://www.youtube.com/watch?v=mVxKFZj9hY0
    More Tilt and Trim
    https://www.youtube.com/watch?v=NBKhlNOcOA8
    Electric Steering in action
    https://www.youtube.com/watch?v=Le6ckg3Qums
    John
  9. #49
    Apr 2016
    Re: 2 X 72 Grinder Pillow Block Toor Bar
    John
    I am new to cnc and have just gained access to a Haas machine just like yours
    do you share drawings for the grinder
    Thanks glenn
  10. #50
    Hi Glenn,
    My apologies for missing your post to this thread.
    Yes, I will share drawing for this project FREE of Charge. It will be a little pay back for all the input and help that I have received over the years from some really great guys in the CNC community.
    I have all the DXF files and a few other formats and other information that is loaded on my Google Drive that I can share.
    I will send you a PM with all the details.
    John
  11. #51
    Feb 2011
    91
    John
    If you are still around this topic i would love to get the drawings if still available.
    Been on CNCZone for years but only found this by seaching for groinders on google.
    Never thought to search on the Zone.
    Mike
  12. #52
    Jul 2012
    29
    Sent from my SAMSUNG-SM-N920A using Tapatalk
  13. #53
    May 2016
    35
    Quote Originally Posted by whimsical View Post
    John
    Mike
    I would also be interested in the drawings if they are still available, very nice build.
  14. #54
    Nov 2010
    39
    Hi Glenn,
    John
    Awesome belt grinder.
  15. #55
    Feb 2006
    Hi John. Beatifull work.
    Ricardo
  16. #56
    Feb 2006
    Ricardo
  17. #57
    Sep 2016
    4
    I would be intetested in the dxf files, if still available
    Thank You
  18. #58
    Nov 2017
    hello can i get the drawings or dxf files please if they are still available ?
    Barulo
  19. #59
    Mar 2006
    371
    I would be intetested in the dxf files too
    Cheers
    SF
  20. #60
    Jan 2018
    John,
    PM sent.
Page 3 of 4 1234
  1. KMG clone belt grinder ( pics )
    By katran in forum Uncategorised MetalWorking Machines
    Last Post: 05-19-2016, 12:39 AM
  2. building manuel surface grinder and a od grinder
    By toolsrule in forum Benchtop Machines
    Last Post: 12-02-2015, 11:20 AM
  3. sunnen grinder lathe attachment or in block grinder?
    By Goldhunter_2 in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2011, 01:42 PM
  4. Need Sherline Belt & qestion on X2 Belt Drive?
    By Oldboy in forum Benchtop Machines
    Last Post: 03-06-2008, 07:42 AM
  5. Belt size/spec for Sieg X3 driving belt
    By rashid11 in forum X3/SX3/G0619/G0463
    Last Post: 02-10-2007, 02:01 PM
