Hi All,
I've been a user of Mach since its very early days, about 2002, I think.
The recent developments IE, endless time for Mach 4, the move of Tormach to Linux, lead me to think I should look at linux cnc again. So I just went to the .org site and started to look at the getting started guide. If that gets anyone started, I'm amazed.
In the hardware needed part they spend endless words telling about the computer; that's easy!
What I presently run is a system of 5 servos, with encoders, a ESS, ( Ethernet Smoothstepper), 5 Geckos. I use a Pokeys board to send certain input to the system, mostly emulations of screen buttons. I use the same system for both Milling machine and Lathe by changing Mach profiles and switching leads. I use custom screens that I've created using Visual Basic, but my programming knowledge ends there.
So, I guess I need a "switching from Mach 3 to LinuxCNC for dummies" manual.
The very first question is what hardware do I really need and what does it cost, although I suppose I can lookup the second part.
I'm especially fascinated by the electronic gearing of a spindle and axis which I understand is something LinuxCNC can do. This would enable true hobbing of gears, generation of worm gears as well as very accurate threading.
I realize it is entirely probable that all this has been covered but the zone's search facility being what it is, I'm asking the questions again. If the answers are already somewhere, please point me.
Thanks in advance,
Jerry "Ozzie" Pryor
